Author Topic: V6 Water Leak  (Read 5017 times)
star_whites
  • Rotherham
V6 Water Leak
« on: 31 December 2008, 14:38:35 »
Hopefully one of you may be able to give me a few ideas.
My 3.0 V6 1999 has started with a water leak. I noticed it due to using 1 litre of water over two weeks but due to the cold water I have noticed what I first thought was smoke but is steam coming from under the bonnett on the passenger side of the engine bay.
On taking a closer look I could see one or two drops of water dripping off the gearbox bellhousing but nothing really. I then popped the bonnett and could see that the water was dripping onto the passenger side manifold/downpipe causing the steam.
At first I was thinking heater bypass valve leaking but now Im not so sure as that is situated more to the left hand block than the right.
Anyone got any ideas??
duggs
  • Felixstowe
    • BMW 3.0 Sport
Re: V6 Water Leak
« Reply #1 on: 31 December 2008, 14:58:25 »
Get it checked out properly and don't drive her too much.
A water leak in the same place for me, turned out to be a water hose right at the back.
A £5 hose cost me over £350 cause the dripping buggered up the Dis pack. Tis a pain but get it sorted...sooner the better.
Re: V6 Water Leak
« Reply #2 on: 31 December 2008, 15:01:05 »
I  would still be looking first at the HBV as that is the most common fault that causes this kind of coolant loss, and it fairly easily checked by removing the wipers and lifting the scuttle out of the way to observe the HBV from all angles. ;)
The water could easily be flowing down the pipes onto the left hand side of the engine and onto the gearbox, although with mine it all seemed to flow out onto the right side! ;)
Re: V6 Water Leak
« Reply #3 on: 31 December 2008, 15:03:21 »
As Lizzie says, I would check the heater bypass valve first ;)
star_whites
  • Rotherham
Re: V6 Water Leak
« Reply #4 on: 31 December 2008, 15:08:57 »
Is the same HBV as fitted to a 2.0 as I have a spare for a 2.0??
jonathanh
  • coventry
Re: V6 Water Leak
« Reply #5 on: 31 December 2008, 15:11:07 »
yep - common across most of the VX range I believe
RichB
  • Loughborough
Re: V6 Water Leak
« Reply #6 on: 31 December 2008, 16:59:59 »
I have exactly the same leak but i'm pretty sure its not from the HBV and I had a new Vauxhall one a few months ago.  Mark is going to help me have a look at it later on in Jan so if we find anything we will let you know, and if you find out where its coming from please let me know so we can check that out too.
Cheers,
Richard
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: V6 Water Leak
« Reply #7 on: 31 December 2008, 17:06:21 »
This is what the HBV looks like mate  :y
http://www.omegaowners.com/forum/YaBB.pl?num=1192574064
v6coop
  • Nottingham
Re: V6 Water Leak
« Reply #8 on: 01 January 2009, 20:01:04 »
You may want to look at this post http://www.omegaowners.com/forum/YaBB.pl?num=1218214895/10#10 for other possible sources if not the Heater Bypass valve. Not sure if they are likely to leak onto the manifold though.
Edit - Might help now I've put the link in  ;D
« Last Edit: 02 January 2009, 07:34:07 by jonlew5 »
Jack-V6
  • Netherland
    • omega Y2.5DTI 2003
    • opel omega portal
Re: V6 Water Leak
« Reply #9 on: 01 January 2009, 21:56:13 »
I have the same problem,
It's not the HBV i've changed it yesterday.
Its also leaking petrol on the passengersite (seen as RHD)
only tis is leaking near to the oilfilter not on the gearbox.
i can't see where its coming from.
Gr Jack
Re: V6 Water Leak
« Reply #10 on: 01 January 2009, 23:20:50 »
Gr Jack
I know I could be very wrong here, misunderstanding your engine layout on a left hand drive vehicle, with petrol leaking on the passenger side (drivers side in Britain). ::) ::)
But the oil filter on RHD vehicles is on the passenger side (your drivers side), so if petrol is leaking onto it, i.e. from the left hand side of the engine to the right, that must be very worrying!! :o :o
I would certainly not use it until you know where it is leaking from. ;)
« Last Edit: 01 January 2009, 23:21:23 by Lizzie_Zoom »
Jack-V6
  • Netherland
    • opel omega portal
Re: V6 Water Leak
« Reply #11 on: 01 January 2009, 23:37:03 »
Gr Jack
Oil filter fitted on the left side of the engine.
Its the same as in britain.
But becaus i'm driving an LHD i try'd to explain it for a RHD.
it is al the same exept the steering wheel.
I don't srive the car until it's repaird.
Gr Jack
« Last Edit: 01 January 2009, 23:38:11 by Jack-V6 »
v6coop
  • Nottingham
Re: V6 Water Leak
« Reply #12 on: 02 January 2009, 07:39:06 »
Sorry I missed the link out of my post higher up the page. I have inserted it now.  ::)
« Last Edit: 02 January 2009, 07:39:22 by jonlew5 »
Re: V6 Water Leak
« Reply #13 on: 02 January 2009, 07:46:29 »
Gr Jack
Gr Jack
Yep, so I was right in my understanding with the oil filter on the left of the engine looking out from the drivers point of view, for either RHD or your LHD. ;) ;)
That does confirm my concern that petrol is going from the right side of the engine (again looking out as the driver would), where all the fuel workings are, to the side of the oil filter.  That signifies a major leak of some kind, and I am very pleased to hear you will not be driving the car until fixed!! 8-) 8-) :D ;)
Jack-V6
  • Netherland
    • opel omega portal
Re: V6 Water Leak
« Reply #14 on: 02 January 2009, 10:08:03 »
Ihave a little boy 5 months i don't take a risc.
I think it's the injectionrail.
But the water leak, i can't find the problem, it's leaking realy bad.
Page created in 0.212 seconds with 16 queries.
