Author Topic: HID Headlight Adjustment ?  (Read 1558 times)
bigdods
  • Brackley
« on: 02 January 2009, 23:02:01 »
OK, maybe Im just being daft but I cant seem to adjust the HIDs on my Elite ? The adjuster motors work fine but they are just pointed a bit too low. I want to ease the beam up a bit and assumed it would just be a case of turning an adjuster but I cant seem to work it out !
Looking at the rear of the o/s lamp I can see two white pegs which I assumed would be turned , one for height the other for left/right but when I try to turn them they dont budge. AM I trying to turn the wrong thing ? where are the adjusters hidden or am I just doing it wrong.
Cheers
Dodsy >:(
Re: HID Headlight Adjustment ?
« Reply #1 on: 02 January 2009, 23:10:59 »
manual adjusters are on each light.  remember they are automatically adjusted, before setting too high, check aim is ok
unlucky alf
  • worksop, notts
« Reply #2 on: 02 January 2009, 23:14:08 »
there is 2 allen keytype screws on the front of the light unit [facing forwards], you turn those & it turns the white thing you are referring to :y [up & down is the top one]
bigdods
  • Brackley
« Reply #3 on: 02 January 2009, 23:27:07 »
aha I assumed you just turned the white thing. So its an allen key adjuster...well in that case it will be done tomorrow.
HerefordElite
  • Hereford
  • Welcome to the Shire
« Reply #4 on: 03 January 2009, 01:36:33 »
very fine adjustment due to ratio of screw to 'white thing' - if you need to move it a lot like setting up from scratch after replacing lamp internals then use a hex drive (allen key) in a battery drill like i did ;)
« Last Edit: 03 January 2009, 01:36:58 by herefordelite »
« Reply #5 on: 03 January 2009, 02:08:37 »
steady though, white thing is only plastic and can seize all to readilly. Not the best design.
Ian_D
  • York
« Reply #6 on: 03 January 2009, 02:15:05 »
Agree. May need a bit of WD40 on it, and work it back and forth till it moves, and thats if the adjuster hasn't snapped off inside anyways as there crap!   :(
[size=12]
« Reply #7 on: 03 January 2009, 19:42:57 »
I wouldn't recommend WD40 for this job.... seriously ... :(
WD40 is a water dispersant, not a lubricant, and the carrier fluid is a solvent which has a tendency to "eat" certain plastics !!!!. If this occurs you have a soggy plastic mess to clear up, and the light will be FUBAR
3in1, or a similar light oil, or preferably a "penetrating" oil is what you need.
edited for smelling pistakes
« Last Edit: 03 January 2009, 19:43:37 by entwood »
Ian_D
  • York
« Reply #8 on: 03 January 2009, 20:51:52 »
Yes thats true thinking about it, just couldn't think of 'penetrating oil' at the time!  ;D
[size=12]
« Reply #9 on: 04 January 2009, 00:41:38 »
WD40 isn't all bad, there are better lubricants, but if that's all you have.  ;)
WD40
LUBRICATES: WD-40's lubricating ingredients are widely dispersed and hold firmly to all moving parts
PENETRATES: WD-40 loosens rust-to-metal bonds and frees stuck, frozen or rusted metal parts
