Author Topic: V6 Injectors & Ultrasonics  (Read 890 times)
HerefordElite
  • Hereford
  • Welcome to the Shire
« on: 04 January 2009, 19:12:31 »
Does anyone know if Vectra 2.5v6 injectors (part no 0280155712)are the same as 3 litre Omega ones? :-?
Also how do you clean injectors? the wife is a dental nurse and has access to an ultrasonic bath do you think this would be suitable? :-?
I have an old xe fuel pump in garage and would set up a rig to test flow after cleaning ;)
Re: V6 Injectors & Ultrasonics
« Reply #1 on: 04 January 2009, 19:31:27 »
A good ultrasonic bath is the job.....quite simply you dip them so the ends are in the bath which is filled with injector cleaner and pulse them whilst they clean....the ultrasonic bath then forces the cleaner in a reverse direction through the injectors
« Reply #2 on: 04 January 2009, 19:36:56 »
Wonder if my brother has a spare ultrasonic bath...  ...doubt he'll let me use his one that he uses and fill it with injector cleaner!
« Reply #3 on: 04 January 2009, 19:37:29 »
 the wife is a dental nurse and has access to an ultrasonic bath do you think this would be suitable? :-? .....
I think the dentist is the man to ask  ;) ..... to be hoped it'll well cleaned out before the next patient. ;D  ;D  ;D
« Reply #4 on: 04 January 2009, 19:38:12 »
400W with a heater is the ideal....
555 timer works well as the driver!
« Last Edit: 04 January 2009, 19:38:27 by Mark »
