Author Topic: trouble with car this morning!!  (Read 1190 times)
mick-1975
  • nottingham
« on: 06 January 2009, 15:00:55 »
 :'(  hi guys woke up this morning for work at half 1,
went to car and you guessed it would not start it would turn but no joy
 got booster out and still no luck .
After a couple of minutes it started  :y.
  anyway i took it to garage  to be tested and charging is ok so i am putting it on charge tonight!!
  could there be anything else that i should keep in mind or is it just this cold weather ?????? :'(
 thanks
Re: trouble with car this morning!!
« Reply #1 on: 06 January 2009, 15:23:23 »
 thanks
When was it last given a full service? :-?
It is when weather is like it has been that you can discover how well your car has been maintained or not! ::) ;)
« Last Edit: 06 January 2009, 15:24:40 by Lizzie_Zoom »
ians
  • Reading
« Reply #2 on: 06 January 2009, 16:02:56 »
if your battery is at all dodgy, then this weather will find it out.   Are you doing long enough drives to charge it up? (bearing in mind you will no doubt have lights, and heaters going full blast..?
Danny
  • Wigan, Greater Manchester
« Reply #3 on: 06 January 2009, 16:15:01 »
my bro has had his lexus for over 2 years with no fault at all but a cold snap a couple of weeks ago killed his battery while he was at work during the day
mick-1975
  • nottingham
« Reply #4 on: 06 January 2009, 17:31:26 »
thanks i travel about 10 mile to work !!
  i did a paper clip test and got
  1 flash and then
 10 flashes 3 times
then back to the one flash
 any ideas ??
 as for the service i do it all my self prob could do with plugs i think but been running great before today !!
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
« Reply #5 on: 06 January 2009, 18:44:54 »
  1 flash and then
 10 flashes 3 times
 any ideas ??
that ten flashes could actually be 1 and 19 making 19 which is the crank sensor!
which would stop it starting... meaning its on the way out
V8!!!!
