Author Topic: Idle Speed in Extreme Cold  (Read 1168 times)
cbowditch
« on: 06 January 2009, 08:43:02 »
I noticed last Winter when the temperature was below -5, the idle speed on my 3.0 V6 would drop from 600 to 500 and start to have a rough feel. The Temp was -8 on my way to work today and after about 30-40 mins of driving the idle speed went down. Hopefully days when the temp is less than minus -5 should be few and far between, but does anyone know if this is to be expected or is there a possible fault in my car?
« Last Edit: 06 January 2009, 08:43:40 by cbowditch »
Re: Idle Speed in Extreme Cold
« Reply #1 on: 06 January 2009, 08:54:41 »
I saw -8ºC this morning - once started idling speed normal (600rpm)
« Reply #2 on: 06 January 2009, 09:18:43 »
theoritically very cold weather means more air ..in this scenario ECU must correct the air fuel ratio with more fuel resulting the revs to go normal or high..so not normal..try unplugging MAF ..and check whats happening..
(assuming air temperature sensor normal as they rarely become donald)
« Last Edit: 06 January 2009, 09:19:06 by cem_devecioglu »
cbowditch
« Reply #3 on: 06 January 2009, 18:54:18 »
Idle speed was fine for the first few miles of driving. The problem only seemed to occur after say 20 miles. It did it on the way home too when I saw -9  :o
philhoward
  • Staffs
  • Love the engines, so put one in something else..
« Reply #4 on: 06 January 2009, 18:57:49 »
cem, your grasp of the English language, and its slang amazes me..
Back to the original problem - mine started hunting a bit tonight, but only after a minute of being stationary.  My fuel consumption has gone to pot the last few days with the weather though - 160 miles and it's sitting on the 40 litre mark - it's usually much nearer 200 miles..
Running an X30XE in a Reliant Scimitar GTE as I can't have an Omega as a company car...
