Author Topic: Headlight Field/vision  (Read 4513 times)
Dazzler
  • Haverhill, Suffolk
« on: 01 January 2009, 11:05:21 »
What is the above telling me??
Is it the level sensor not working in some way on the n/s wishbone or something else??
TIA
Happy New Year to you all :)
Re: Headlight Field/vision
« Reply #1 on: 01 January 2009, 11:07:53 »
headlight levelling not working.
Usual culprits are the 2 suspension sensors or the servos, with front suspension sensor being most common.
Dazzler
« Reply #2 on: 01 January 2009, 11:12:55 »
Where is the other sensor then Jaime?
The servos etc....were all tested by Kevin about a month ago and were all working fine :(
« Reply #3 on: 01 January 2009, 11:35:47 »
both sensors are pass side, front wishbone bracket to body, turn wheel to right lock and pear in between wheel and door. Its probably popped off since last time the car was jacked up or whatever. Clean and pack with grease then push back on firmly into the ball joint but its probably buggerd.
Rear can be seen between door and wheel on rear wishbone iirc.
Dazzler
« Reply #4 on: 01 January 2009, 12:04:24 »
I thought the rear one was for the self leveling suspension :-/
« Reply #5 on: 01 January 2009, 12:08:29 »
No, sl is a  square box with a right angle lever/arm and plastic rose joint by the fuel filter.
« Reply #6 on: 01 January 2009, 15:38:16 »
That one is on the driver's side. :y
Dazzler
« Reply #7 on: 01 January 2009, 16:40:02 »
ok ta ;)
Will try and investigate tomorrow :y
« Reply #8 on: 01 January 2009, 16:56:18 »
ok ta ;)
Ultimately, you might need it plugging in to a TechII to find out what upsetting it. I don't know if a Cheapo TechII will read the fault. :-/
benbrunt
  • Oldham
« Reply #9 on: 01 January 2009, 20:25:50 »
ok ta ;)
The "My Naff Code Reader" system will, it can be found on ebay, but there are doubts over the authenticity of the software that comes with it. Mine is saying Field/Vision and it tells me its a problem with the drivers' side headlamp. Hope that helps
<marquee>[img name=signat_img_resize]http://farm4.static.flickr.com/3208/3130811192_b672fbed66_m.jpg[/img]
Gas Guzzler, I love the stuff!
Dazzler
« Reply #10 on: 02 January 2009, 17:47:56 »
Level sensors checked, all free to move and not broken.
I have manually moved the headlamp adjusters as these were lowered for the MOT >:(
Message has cleared at the moment.....fingers crossed. Will have to wait and see.
If that fails then will have to get it Tech11ed.
« Reply #11 on: 02 January 2009, 17:52:21 »
Level sensors checked, all free to move and not broken. ........
Mine looked OK but a 'new' FNS sensor cured my message.
« Reply #12 on: 02 January 2009, 18:12:02 »
The headlamp levelling MUST work (legal requirement), the fact you have that error is a warning its NOT working.  The system will try to lower lights as low as possible to ensure no glare to other road users.
Fix the fault, not bodge the symptom ;)
Dazzler
« Reply #13 on: 02 January 2009, 20:40:20 »
Boll*x.....warning persists >:(
Will have to be a Tech11 i think :(
alexandjen
  • Sittingbourne, Kent
  • The Silver Surfer
« Reply #14 on: 02 January 2009, 21:11:33 »
Check the wiring where it enters the plugs at the sensors on the suspension.
I the same problem with mine and after changing most of the componants it turned out to be one of the wires on the front sensor right at the point where it enters the plug, it had broken within the insulation.
Trade club card holder
Code scanner available
Page created in 0.145 seconds with 16 queries.
