Author Topic: Steering Idler - tools required  (Read 1793 times)
Martin_1962
« on: 07 January 2009, 13:10:35 »
So what do I need to warm up overnight before doing the idler?
Thanks
HerefordElite
  • Hereford
  • Welcome to the Shire
Re: Steering Idler - tools required
« Reply #1 on: 07 January 2009, 13:14:35 »
Thanks
very good question Martin, i jacked mine up on Monday and gave it a damn good soaking in Plusgas ready for arrival of new idler (hopefully today) :)
Guessing it's just a set of spanners and a balljoint splitter for the tools? :-?
we should have a local "steering idler party" ;D
« Reply #2 on: 07 January 2009, 13:16:18 »
Thanks
Garage!  ;)
17 or it might be 19 mm spanner/socket and 2 hammers to gently persude the taper to let go of the idler.  :y
« Reply #3 on: 07 January 2009, 13:17:56 »
Thanks
Garage!  ;)
;D ;D
It might start off gently, but just wait until you clout your hand on something ::)
Martin_1962
« Reply #4 on: 07 January 2009, 13:53:25 »
Thanks
I better get one :o
« Reply #5 on: 07 January 2009, 13:54:28 »
No need for a ball joint splitter for his job!
HerefordElite
  • Hereford
« Reply #7 on: 07 January 2009, 15:42:32 »
http://www.omegaowners.com/forum/YaBB.pl?num=1158598664  :y :y
i thought i'd read every guide in the maintenance section :-[, must have missed this one ::)
« Reply #8 on: 07 January 2009, 16:28:41 »
I couldn't actually make fit my bal joint splitter in, so had to use the heavy handed method of 2 knocking sticks. :y
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #9 on: 07 January 2009, 16:43:19 »
Wish I had found that before doing mine!! numerous skinned knuckles and balljoint splitter slipped off ond hit me in the face while under tension !! OUCH
HerefordElite
  • Hereford
« Reply #10 on: 07 January 2009, 22:02:35 »
Right done it :) not to bad really, few differences with Ronald Mcburger's method though http://www.omegaowners.com/forum/YaBB.pl?num=1158598664 :-?
1. Both the rear idler to bracket & the front idler to steering arm were 18mm?
2. Struggled to get the old idler off, managed in the end by getting big bar in on top of the steering rack right on the idler joint and then levering towards front of car under the wishbone mount - then tw4t the idler up with a big hammer till it 'pops' off like Ron says :y
3. When i came to tighten up the new idler onto the s/rack joint it kept turning so i used a trolley jack under the joint to put pressure on it so that the tapper gripped ;)
4. To torque the idler to steering rack joint there was insufficient room to get a torque wrench in from the wheel arch :-/ but if you centre the steering i found that with 3 extension bars (approx 2 foot!) you can get on to the bolt through the engine bay between the oil filler (V6) and the scuttle :y
All in all not too bad, hardest part was getting the old bits apart as usual ::)
Took it for a run down the road and i hadn't realised how bad the steering must have got over the years :o :o :o
It's SO much nicer to drive now :y, tighter :y, doesn't wonder or tramline :y and the 65mph speed vibration has gone :y :y :y :y
« Last Edit: 07 January 2009, 22:04:14 by herefordelite »
« Reply #11 on: 07 January 2009, 22:28:22 »
1. Both the rear idler to bracket & the front idler to steering arm were 18mm? ......
I was only 0.039" out with both my guesses!   ;D  :y  :y
HerefordElite
  • Hereford
« Reply #12 on: 07 January 2009, 22:35:29 »
0.03937" to be precise but i'll let you off ;)
« Reply #13 on: 07 January 2009, 22:52:31 »
Thanks!  ;)  ;)  ;)
& I thought I was being accurate, I usually use 40 thou!  :y  :y
HerefordElite
  • Hereford
« Reply #14 on: 08 January 2009, 13:06:50 »
bump for Martin to see ;)
