Author Topic: Auto Gear Box oil Change  (Read 1432 times)
hp7166
  • Bridgend
« on: 08 January 2009, 10:48:33 »
Hi Guys
I need change the gear box oil as i keep getting a few judders now and again, i have got the guide can you tell me how much oil i need to buy to do a full change
Cheers
Rob
« Last Edit: 08 January 2009, 11:18:53 by hp7166 »
benbrunt
  • Oldham
Re: Auto Gear Box oil Change
« Reply #1 on: 08 January 2009, 12:04:36 »
From dry Haynes states 8.4 litres approx
<marquee>[img name=signat_img_resize]http://farm4.static.flickr.com/3208/3130811192_b672fbed66_m.jpg[/img]
Gas Guzzler, I love the stuff!
hp7166
  • Bridgend
« Reply #2 on: 08 January 2009, 12:50:28 »
Thanks for that, Does anyone know how i get the nozel to put the oil in?
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #3 on: 08 January 2009, 13:12:10 »
Where are you at exactly?
benbrunt
  • Oldham
« Reply #4 on: 08 January 2009, 13:19:26 »
Varche
  • middle of Andalucia
    • Golf Estate
« Reply #5 on: 08 January 2009, 13:19:50 »
Don't quite know what you mean but I have used a number of methods to get the oil in the level check hole on the drivers side of the gearbox. I have yet to buy a bottle of DEX111 oil with a filler tube included.
One uses about a metre length of 1/4 inch clear plastic tube with a funnel in the top. Thread it OVER the exhaust and up through the engine compartment. Helper pours in while you hoild it clear of the exhaust and in the hole. It wastes a bit of oil when you pull it out but you already know the job is a bit messy. Others have used Hozelock sprayers to good effect. Hope that helps.
varche
hp7166
  • Bridgend
« Reply #6 on: 08 January 2009, 13:25:53 »
In Bridgend
Seth
« Reply #7 on: 08 January 2009, 13:42:26 »
In Bridgend
I'm in Maesteg.
I've got an air-operated oil can 'thingy' that I want to try out.
Do you want to be my first victim?
I'm here this afternoon - send me a 'PM' with your phone number, and I'll see if I can oblige!
