Pages: [1] 2 3  All   Go Down
Author Topic: Auto gear box problem  (Read 5057 times)
mickfit
  • Ireland
  • "No fate, but wot we make!!"
« on: 24 December 2008, 19:28:36 »
Hi folks
          Read a recent post today frm seanboy40.....
 I have a similar problem, my car will select reverse ok but when i select drive or even 1 2 3 no movement at all. Now not even the very slight thump (as you would expect) to let you know that your engaged in gear.....
 Any suggestions :( :(
Please help
mickfit
Mickfit
Richie London
  • heathrow
Re: Auto gear box problem
« Reply #1 on: 24 December 2008, 19:57:50 »
Richie London
  • heathrow
« Reply #2 on: 24 December 2008, 19:58:44 »
try this m8
http://www.omegaowners.com/forum/YaBB.pl?num=1152783586
im a bit of a novice but some great answers will arrive shortly
mickfit
  • Ireland
« Reply #3 on: 24 December 2008, 20:09:04 »
Richie rich
              Thanx forthe very quick response, but had the oil and filter changed bout 4 wks ago with o.e. filter and gasket and dexron III recommended atf. Now i'm not a mechanic but would might be what you would call "novic mechanically minded", i helped change the oil and filter and i dont think it was ever done (149k). Had a lot of wrk cleaning out the sump and had a bit of bother finding the little magnet....
Mickfit
« Reply #4 on: 24 December 2008, 20:12:26 »
Now this might sound daft .. but was the level filled CORRECTLY ... on the miggy it is done with the engine running, or you end up with a very low level, which might be your problem ...not enough fluid in the system.
My first thought would be to have the level checked, ensuring the vehicle is level, and the engine is running.
Richie London
  • heathrow
« Reply #5 on: 24 December 2008, 20:15:22 »
i had a bit too much in mine when i checked it last month, took a bit out and the gear changes are very good now, very smooth when the engines hot and a brilliant kick when i boot it at 70  :-X
markey mark
  • SLady bitshorpe north lincs
« Reply #6 on: 24 December 2008, 20:15:38 »
i would agree make sure you have the right level in box !  :y
mickfit
  • Ireland
« Reply #7 on: 24 December 2008, 20:19:53 »
          Thanx for your reply, we filled the sump up to the bung level then raised the sump up to box then tightened. I then took it for a short run ( to reach op temp) then rechecked oil level and topped up accordingly so............ not sure wot to do now mate???
Mickfit
markey mark
« Reply #8 on: 24 December 2008, 20:23:42 »
get it to opearting temp and check level again on a level ! you might find its dropped a good bit ! do you know how much oil you put in ?? :-?
mickfit
  • Ireland
« Reply #9 on: 24 December 2008, 20:23:45 »
Well, is the bung the rite level or is their something i'm missing. When car is running i loosen the bung and a little oil comes out.......
Mickfit
mickfit
  • Ireland
« Reply #10 on: 24 December 2008, 20:28:20 »
No, but when i bought the atf they said it was listed as taken bout short of a gallon....
Mickfit
markey mark
« Reply #11 on: 24 December 2008, 20:31:55 »
thats not right iirc they take 7.5L ! :o :o
« Reply #12 on: 24 December 2008, 20:33:36 »
okay ... if you filled it correctly 4 weeks ago; car level, engine running just to the "bung" level ...... and now when you put the car to the same conditions and remove the bung fluid comes out, then you probably have a fairly serious box problem.
The reason I say this, is AFAIK, as ATF fluid breaks down through excess heat or stress, which can include excess slippage or "burning" at the fluid clutches, the polymers actually get longer, so giving the impression of an overfull system.
I mean .. if it was correctly filled, where has the "extra" fluid come from to dribble out ?
I hope I'm wrong for your sake ... but an expert will pass by and correct me soon I expect ...
mickfit
  • Ireland
« Reply #13 on: 24 December 2008, 20:41:55 »
I think i will take your advise and recheck the oil level again....
Just want to say that i'm very grateful for all your help
p.s. Just a quick question,
                                  It'll select reverse ok but just no action in any forward gears, i had someone mention to me bout a selector switch???
Any ideas or i'm i grasping straws ::)
Mickfit
« Reply #14 on: 24 December 2008, 20:56:29 »
Not too hot on the selector switch side of things .. but AFAIK all the valves are electrically operated from the ECU...
If memory serves me.. and it probably doesn't... a feature of low oil level is that reverse works when forwards doesn't, .... I think that reverse has a shorter internal path so requires less fluid to work.
I'm concerned that you filled the sump before refitting and then drove the car without checking the level. You may just be well short of fluid, or you've damaged something. 1 gall (4.5 ltrs) does not seem anywhere near enough fluid IMHO
Pages: [1] 2 3  All   Go Up
