Author Topic: Engine Oil Leak 2.5 V6 CDX  (Read 2893 times)
MadJimmy
  • Birmingham
Re: Engine Oil Leak 2.5 V6 CDX
« Reply #15 on: 09 January 2009, 19:13:21 »
im starting to wander if he changed the engine at all
wish i could prove if he did or not :o
James
There and Back Transport Ltd
www.thereandbacktransport.com
Vauxhall Omega 2.5 V6 CDX Saloon
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
« Reply #16 on: 09 January 2009, 19:16:17 »
if you want to check if he has then compare the engine number on the v5 to the one situated just above/to the right of the oil filter (its stamped in running vertical from memory) (if you turn the steering to full lock right and jack the front left up you should beable to shine a torch to see it instead of climbin under the car :y
V8!!!!
MadJimmy
  • Birmingham
« Reply #17 on: 09 January 2009, 19:18:36 »
i will do that tomorrow in daylight and after ive cleaned engine as covered in oil lolx
just hope for his sake he has changed it >:( there be trouble if he hasnt
James
ngrainqey
  • rotherham
« Reply #18 on: 09 January 2009, 19:20:12 »
i seriously doubt he has if you had a bad oil leak and it still has one
V8!!!!
MadJimmy
  • Birmingham
« Reply #19 on: 09 January 2009, 19:22:41 »
the last one was coming from the cover gaskets for sure as the heat sheild was soaked in it
i think im looking for things that aent there cos the trouble im having but its just a niggling doubt that im getting
James
MutantCav
  • Gainsborough
« Reply #20 on: 09 January 2009, 19:22:56 »
As Alex says, engine number is stamped on a plate by the oil filter...and is also on the V5C doc...
If the V5C for your car hasnt been changed to show the new engine number then obviously the engine number of the engine in your car now should be different to the V5C engine number on your cars docs :)
MadJimmy
  • Birmingham
« Reply #21 on: 09 January 2009, 19:24:58 »
yep that what i thinking now lol will check first thing once engine cleaned
James
