Author Topic: Drivers leather heated seat not working.  (Read 3214 times)
garbage456
  • Carshalton, Surrey
« on: 07 January 2009, 12:49:22 »
for about 2 weeks the drivers seat has gone to burning mode whatever number I put the dial on between 1 and 5, now it has stopped working altogether, the light next to the dial comes on but no heat.
Any ideas please.
garbage456
Re: Drivers leather heated seat not working.
« Reply #1 on: 07 January 2009, 14:35:30 »
is there a guide on here, i went through all 6 pages but could only find cloth instructions about removal, but i dont know if it is in the same place on the leather
any help will be great thanks
jjleonard
  • stevenage
« Reply #2 on: 07 January 2009, 14:37:35 »
From what I can tell from the posts on here (i have leather myself), the pad is stitched to the seats and difficult to replace. Given the amount of work required to take the seat apart - unstitch and re-stitch the leather, it may be easier to replace the whole seat. (or do without the heat!)
Several breakers on here who should be able to assist.  :y
garbage456
« Reply #3 on: 07 January 2009, 18:09:30 »
thanks for the tip
« Reply #4 on: 07 January 2009, 18:53:26 »
Contact a specials car upholstery place for a quote to replace heater pads, though on facelifts, may be worth checking stat first
kevpuk
  • Poole
« Reply #5 on: 07 January 2009, 19:47:13 »
Stat ? My drivers seat (leather) does not work.....passenger and rears all fine - go figure  :( - what to check ?
benbrunt
  • Oldham
« Reply #6 on: 07 January 2009, 20:47:01 »
I think you can stick a replacement pad under the leather covers in a frakenstein type fashion similar to the cloth ones, failing that a fan heater in the rear footwell will have to do ;D
<marquee>[img name=signat_img_resize]http://farm4.static.flickr.com/3208/3130811192_b672fbed66_m.jpg[/img]
Gas Guzzler, I love the stuff!
garbage456
« Reply #7 on: 09 January 2009, 15:57:14 »
so what has failed is it litterally the pad in the drivers seat, no wires or fuse boxes no?
benbrunt
  • Oldham
« Reply #8 on: 09 January 2009, 17:48:35 »
Check if you have power at the switch, if you do I would say that the pad itself would be the prime candidate
« Reply #9 on: 09 January 2009, 19:14:10 »
99.99% of the time it will be a failed heater pad.  On facelifts, there is a stat under the seat that worth checking first...
Richie London
  • heathrow
« Reply #10 on: 09 January 2009, 19:35:43 »
mine stopped working ages ago. but im wellard southerner and can cope with cold bottom  ;D ;D
Richie London
  • heathrow
« Reply #11 on: 09 January 2009, 19:36:27 »
is it possible to swap the front seats over at all?
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
« Reply #12 on: 09 January 2009, 19:53:43 »
yeah you can swap the seat for another drivers seat or just get a heater pad and stick it under the existing pad and it works ok
V8!!!!
Richie London
  • heathrow
« Reply #13 on: 09 January 2009, 20:05:38 »
sorry,i meant swap passenger and driver seat over
ngrainqey
  • rotherham
« Reply #14 on: 09 January 2009, 20:24:52 »
i think they're a straight swap but buttons etc will be on wrong side
V8!!!!
