Author Topic: Fitting Spring Set?  (Read 1439 times)
Pete Elite
  • Uxbridge, Middlesex
Fitting Spring Set?
« on: 09 January 2009, 14:40:58 »
Hi all,
       Can anyone tell me if it's ok to fit a set of 2001 MV6 saloon springs to a 1996 3.0L Elite saloon and if so will the rear load leveling suspension still work ok :question.
       Thanks,
                 Pete :).
Re: Fitting Spring Set?
« Reply #1 on: 09 January 2009, 20:03:06 »
It will fit ok....the rear level sensor will want a little bit of a tweak to lower the setting
Pete Elite
« Reply #2 on: 09 January 2009, 22:08:38 »
Thanks for your reply Mark :y.
Glynn
  • wirral
  • 3 LTR ELITE
« Reply #3 on: 09 January 2009, 22:53:44 »
how do you do that ??
[img name=signat_img_resize]http://i24.photobucket.com/albums/c18/glynn969/P8130334-1.jpg[/IMG]
« Reply #4 on: 10 January 2009, 12:11:33 »
Depends on the year of car.....bending the sensor actuator arm is the easy option......Tech2 can also re-config it on post 98 cars
