Author Topic: 1996 2 litre Autobox Issue  (Read 1750 times)
Tony_1985
  • Ellesmere Port, Cheshire
« on: 08 January 2009, 00:13:20 »
I have searched for this and came back with no results
I have an issue with the auto box on my 1996 Omega 2.0
Every now and then, when i put the box into Drive the car will try to pull away as normal with the brake on, but it seems to bounce causing the car to almost stall everytime it tries to pull away
It repeats this until i actually let the brake off, then struggles to accelerate
Not sure if its a problem with the box or just the selector switch
I hope I have worded it correctly
Can someone shed some light on what's making the car do this?
benbrunt
  • Oldham
Re: 1996 2 litre Autobox Issue
« Reply #1 on: 08 January 2009, 09:11:51 »
By 'bounce' do you mean the engine revs fall then rise again to compensate?
<marquee>[img name=signat_img_resize]http://farm4.static.flickr.com/3208/3130811192_b672fbed66_m.jpg[/img]
Gas Guzzler, I love the stuff!
Tony_1985
« Reply #2 on: 08 January 2009, 14:03:20 »
Yeah, but the car seems to do a rocking motion when its in Drive at stand still
I know this isnt normal as I have driven quite a few Autos
HGV mechanic
  • northamptonshire
  • he just keeps on going,,,
« Reply #3 on: 08 January 2009, 14:08:46 »
may be an ICV problem , has it been cleaned recently
« Last Edit: 08 January 2009, 14:09:08 by matthew »
Tony_1985
« Reply #4 on: 08 January 2009, 17:08:15 »
unsure of this as i have only had the car for 3 weeks
think i will do this anyway, the gaskets for them are pennies
will update tomorrow when i have done it
also with it being an N reg, and it's been sat for a while before i bought. It may benefit from an gearbox fluid change
So will also go down that route
« Last Edit: 08 January 2009, 17:13:53 by Tony1985 »
Tony_1985
« Reply #5 on: 10 January 2009, 14:11:40 »
well the good old dealers being what they are, haven't got the parts i need in stock
so this is on hold until monday now as i had to get them to order the parts in for me
going to do this oil catch/fly trap mod as well, just to see if it helps
