Author Topic: Where is the Output speed sensor unit  (Read 1943 times)
SP_3.2
  • Leicester
    • drives A6 allroad 3.0tdi
« on: 08 January 2009, 16:17:33 »
When checking codes last night on a maxscan 380 had a code that i have not see before with a P next to it 0170 i think. Had a check and Output  sensor, where would it be as not had any runing prob since doing the rocker covers and oil cooler .
Thanks
Steve.
Re: Where is the Output speed sensor unit
« Reply #1 on: 08 January 2009, 17:05:39 »
P0170 is a fuel trim malfunction. Do you have the EML on at the moment. If not, it could be an old code.
Could try the pedal trick to double check?
P0170 will light the emissions lamp if it's current, though.
« Reply #2 on: 08 January 2009, 17:09:06 »
What code is it that you`re getting as this was your original post :)
Just had a check with my new u380 scanner that i go from e-bay LOVE IT . Checked the codes and got 0420 which i know about and have cleared but also  0720 with a P next to it which i think is Ouput shaft speed sensor circuit not shur if this is an old code as it had p next to it on the display .
« Reply #3 on: 08 January 2009, 17:17:11 »
Output shaft sensor sounds like the auto gearbox?
« Reply #4 on: 08 January 2009, 17:18:57 »
Sends info to the TCU for gearchanges :y
SP_3.2
  • Leicester
« Reply #5 on: 08 January 2009, 17:22:25 »
Sorry all ::) ::) Yes as you send Rob it 0720 ....Long day.
Is this located at the back of the G Box ...
« Reply #6 on: 08 January 2009, 17:51:17 »
OSS if fitted is positioned at rear end of box. Bear in mind that the car will be fitted with a primary speed sensor. The output shaft sensor is basically a back-up system if the primary one fails in order for the car`s ECU to still collect all relevant data e.g. if cruise is activated. As you state that the car runs OK I would imagine it`s possibly a stored code :y
Matchless
  • Nottingham
    • A white van
« Reply #7 on: 08 January 2009, 18:50:52 »
Do you ever see the gear selector lights behaving oddly when you move the gear selector?
If the gear selector switch is playing up (dirty / corroded) then the gearbox ecu flags a fault because it sees a difference between the gear ratio it thinks is selected and the actual ratio of input and output speeds. The code doesnt necessarily mean that the sensor is faulty.....only that something isnt making sense to the ecu.
« Reply #8 on: 08 January 2009, 18:52:56 »
Nah......output shaft speed sensor is found only on auto boxes and used solely by the auto box ecu!
There is no P0720 for this box, only a P0722!
SP_3.2
  • Leicester
« Reply #9 on: 08 January 2009, 19:05:31 »
Thanks everyone for quick replys will keep an eye on things as see if the code comes up,
Have not had any odd selector light  but will give it a check and clean just to make sure.
Thanks all
« Reply #10 on: 10 January 2009, 12:06:26 »
[split] [link=http://www.omegaowners.com/forum/YaBB.pl?num=1231586488/0#0][splithere][/link][splithere_end]
Derek_in_Penzance
  • Penzance, Cornwall
« Reply #11 on: 10 January 2009, 14:44:44 »
I think the output speed sensor is on to of the gearbox, right at the back end near the output shaft, and at the 1pm position looking backwards. Held in with a 10mm (hex size) bolt.
Go to Facebook and become a Fan of the GM6 Spares Facebook page. Omegas dismantling, mail order parts & servicing. Tech 2 services available.
