Author Topic: Heater Fan keeps popping 30A fuse  (Read 1405 times)
JoeV
« on: 09 January 2009, 09:30:39 »
Hello, All.  Fuse #33 (30A) keeps popping a few minutes after I turn on the heater.  Fan motor was making kind of a squeeling/grinding sound before fuse blew.  Picked up a used fan motor from ebay and replaced the old one.  No more squeeling but fuse still keeps popping!
Any ideas???
Joe  '96 Vauxhall Omega 2.5L V6.
Re: Heater Fan keeps popping 30A fuse
« Reply #1 on: 09 January 2009, 10:07:00 »
Any ideas???
Climate control, or manual heaters?
Also, is the scuttle drain full of water?
mantahatch
« Reply #2 on: 09 January 2009, 11:07:13 »
It may help or may not help, but on mine a few years ago the wiring to the air con pump had chaffed through. It only blew the fuse when the climate control was on.
Mike
Andyb
  • Lincoln
« Reply #3 on: 09 January 2009, 11:11:12 »
also has the voltage regulator burnt out
JoeV
« Reply #4 on: 10 January 2009, 15:41:00 »
1. It's climate controlled.  I'd have to check on the scuttle drain (I don't know what that is).  Didn't check the voltage regulator but I recently ruined a 2-month old battery due to a seized AC compressor.  Tech said that the plates on the battery got affected due to the heavy load added by the seized compressor??? Can't even get the car started - couldn't crank the engine because the AC compressor was keeping everything too tight.  Had to change to a shorter belt to leave out the compressor.  Was going to save it as a summer project.
Really appreciate everyone's comments...  THANKS!!!
Joe
« Reply #5 on: 10 January 2009, 15:46:00 »
