Author Topic: 2.ol engine  (Read 2177 times)
bago
  • Leicester
    • face lift 2.5 Elite bus
2.ol engine
« on: 09 January 2009, 08:01:37 »
Anybody got any idea on a reliable sourcefor a engine for a 2lt cd 99 v plate ?
Re: 2.ol engine
« Reply #1 on: 09 January 2009, 10:15:28 »
We have a few breakers on here who may be able to help...
MutantCav
  • Gainsborough
Re: 2.ol engine
« Reply #2 on: 09 January 2009, 11:43:06 »
Got one here from a 98 S plate CD that will be the same 85k FSH...and not too far from you mate
PM me if interested :)
« Last Edit: 09 January 2009, 11:44:15 by ShieldOfSteel »
Re: 2.ol engine
« Reply #3 on: 09 January 2009, 12:13:47 »
If fitting an X20XEV then make sure its the later unit with the balance shafts fitted!
These appeared in 1998 at around the same time the later ABS setup was fitted.
MutantCav
  • Gainsborough
Re: 2.ol engine
« Reply #4 on: 09 January 2009, 12:55:34 »
How can you tell if it is?? Its a 98 so theres a good chance, its a mini facelift and has solid headrests on the seats...what do I look for?
Re: 2.ol engine
« Reply #5 on: 09 January 2009, 13:33:09 »
Lol.....the certain give away is to look at the inlet snorkel in front of the radiator (behind the grill).....if it has a little resonant stub on it.....its the later engine setup!
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
Re: 2.ol engine
« Reply #6 on: 09 January 2009, 18:51:19 »
whats so much better about the later 2.0?
V8!!!!
Tony_1985
  • Ellesmere Port, Cheshire
Re: 2.ol engine
« Reply #7 on: 09 January 2009, 18:53:45 »
would like to know the same, as i seem to have an earlier 2.0 litre engine (1996)
pulls quite well at 136k
« Last Edit: 09 January 2009, 18:54:03 by Tony1985 »
MutantCav
  • Gainsborough
Re: 2.ol engine
« Reply #8 on: 09 January 2009, 18:55:18 »
Would same later engine also be where the split sump came into being?
ngrainqey
  • rotherham
Re: 2.ol engine
« Reply #9 on: 09 January 2009, 18:57:26 »
yeah the later engine is two piece sump i think
V8!!!!
Omega man 2
Re: 2.ol engine
« Reply #10 on: 09 January 2009, 20:33:35 »
My dad had an older 1997 2.0 and I now have a 1999 and it just seems to have a bit more go in it. I think because the engine has a better balance it rotates easier 8-)
ngrainqey
  • rotherham
Re: 2.ol engine
« Reply #11 on: 09 January 2009, 20:37:06 »
what are the balancer shafts actually balancing? rotation/firing of the cylinders?
anyway if the balancer shaft lump is so good then why do courtenay do a kit to remove them?
V8!!!!
MutantCav
  • Gainsborough
Re: 2.ol engine
« Reply #12 on: 10 January 2009, 10:11:58 »
The big air pipe has a module thing half way down, this what you mean??
bago
  • Leicester
Re: 2.ol engine
« Reply #13 on: 10 January 2009, 10:20:15 »
Pm sent Thks Mutant
MutantCav
  • Gainsborough
Re: 2.ol engine
« Reply #14 on: 10 January 2009, 18:29:47 »
And replied :)
