Author Topic: broken door check straps  (Read 953 times)
blue_dream
  • Wellingborough
« on: 10 January 2009, 00:22:19 »
Hi
   Can anybody on here weild, both my front doors have broken door stays but they have broken form the door shell, was thinking of replacing doors complete if i can find some that are decent and polar sea blue and not about to break again
  I have  repair plates but they dont look to good and look a sod to do
   Help!!!  my legs have many brusies  :(
Re: broken door check straps
« Reply #1 on: 10 January 2009, 11:51:57 »
Hi
Have a read through here, & I'm sure the repair is covered elsewhere on the forum... inc pretty picutres :y http://www.omegaowners.com/forum/YaBB.pl?num=1231427076
MV6Matt
  • London
    • No car since 2022....
« Reply #2 on: 11 January 2009, 08:47:56 »
The way I did mine was to find a donor door and cut out the the intact door check strap anchor point and surrounding area and replace in current door. (I don't weld myself got someone else to do it)
A bit of a long way round (as you say a bit of a sod to do - cos he told me so!) but has worked fine so far and that was 3 years ago.
...only trouble is the bottom of the door is now bubbling with rust! :(
Probably makes more sense to get a replacement door with sound check strap link anchorage and respray.......... ;) Or if you're lucky enough to find a match just a straight swap.......
My front passenger door has now started making horrible noises lately so will probably replace the plastic as in the link already suggested by Andy....
Otherwise it's two doors time! :o
Hope this helps
Matthew
(thanks Ian)
« Reply #3 on: 11 January 2009, 10:29:21 »
if its the door end, the repair kit is cheap and easy...
