Author Topic: Car acting weird this morning  (Read 3249 times)
Pippin
  • Birmingham
    • Vauxhall Signum 1.9CDTi
« on: 10 January 2009, 10:47:46 »
Hi guys...am a little puzzled by what happened to the car this morning...
Went out to start it.. rook a little while to turn over then started to run a little arratic....dropped it into drive the revs started going from just above 500 to 1500 so dropped it back into neutral and was then fine....
over the last couple of days the missus has been using the car whilst i've been away and when i got back home she said there had been a warning lite on the dash illuminated...after a trip to the car for her to show me it was the eml....but now not on..
any ideas?
RoSPA Gold Advanced Driver
Trade Card Holder
benbrunt
  • Oldham
Re: Car acting weird this morning
« Reply #1 on: 10 January 2009, 10:57:49 »
Even though the light isn't on now it should still have a fault code stored. Only way to know for definite is to hook it up to a tech 2 and read the error codes
<marquee>[img name=signat_img_resize]http://farm4.static.flickr.com/3208/3130811192_b672fbed66_m.jpg[/img]
Gas Guzzler, I love the stuff!
Pippin
  • Birmingham
« Reply #2 on: 10 January 2009, 10:59:03 »
I thought that might be the case...... thanks for the reply.. :y
Trade Card Holder
chrisdb
  • Chesterfield
« Reply #3 on: 10 January 2009, 13:22:14 »
Read the Paper Clip test in the how to section. This will explain how to read the codes without tech 2.
TC Card, will buy parts for members near by. V6 Camshaft locking kit can rent out to members at club rates.
benbrunt
  • Oldham
« Reply #4 on: 10 January 2009, 13:45:27 »
Don't think you can paperclip the 2.2
cbowditch
« Reply #5 on: 10 January 2009, 13:57:21 »
I think the paper clip test only applies to prefacelift cars. Pedal trick works on 2.6 and 3.2, but for 2.2 codes you need tech 2  :(
« Last Edit: 10 January 2009, 13:57:37 by cbowditch »
Pippin
  • Birmingham
« Reply #6 on: 11 January 2009, 10:34:18 »
Thanks again everyone, will arrange with one of the guys with a TechII on once i get paid to have a look at it..... :y
Trade Card Holder
mv6copcar
  • Essex, Halstead
« Reply #7 on: 11 January 2009, 19:23:59 »
any ideas?
IAC valve or Crank shaft / cam shaft sensor
Marie
    • 2ltr LPG Estate
« Reply #8 on: 11 January 2009, 21:11:50 »
sounds like its the breathers.
have you had the breathers cleaned out before?
almost every time my car does this its cleared by cleaning the breathers out.
try this before oyu go spending out on bigger parts.
you will need the AIAC seal/gasket as these tend to be once use only.
« Last Edit: 11 January 2009, 21:12:27 by marie »
Tony_1985
  • Ellesmere Port, Cheshire
« Reply #9 on: 11 January 2009, 23:52:31 »
you may have just solved my problem here, as i have a very similar problem and have posted about it before
Im going to be cleaning the IACV and breathers tomorrow, might be worth doing the same to yours
Pippin
  • Birmingham
« Reply #10 on: 12 January 2009, 11:27:23 »
This is probably going to make me sound thick but what is the IACV and where would i find it located on the engine?
Thanks
Trade Card Holder
