Author Topic: please parts nr need  (Read 1419 times)
serek
  • huntingdon
    • 3.2 mv6
« on: 11 January 2009, 21:32:38 »
last week my auto box die, then today I went to buy other one,
 I wont to change oil, filters and gaskets ,
can I have VX nr for that parts please
ohh also when I open biggest sump filter was break becouse sump is dent, do I should worry about this? :(
thanks
Sew
« Last Edit: 11 January 2009, 22:03:30 by serek »
Re: please parts nr need
« Reply #1 on: 12 January 2009, 02:51:23 »
thanks
Sew
Hope its an AR35 rather than the original AR25, you can chip it then without over powering the box :-)
Dont know the part numbers, but yes i think you should worry about the dent in the sump. The dent, if bad enough to damage the filter, will be bad enough to effect the amount of oil the box will take. Auto boxs hate heat and use the oil to cool it down. Less oil means less cooling.
serek
  • huntingdon
    • 3.2 mv6
« Reply #2 on: 12 January 2009, 13:08:11 »
I thing damage happend when braker was taking box off, meybe I swap over sump from my old box ? and yes is AR35
« Reply #3 on: 12 January 2009, 15:53:08 »
If sump and filter are the same size (?) others will know, then yes just clean the filter if its in good condition.
serek
  • huntingdon
    • 3.2 mv6
« Reply #4 on: 12 January 2009, 18:16:16 »
filter is different size then sump but also is 2 inch  crack on filters
need to buy new anyway
