Author Topic: ABS & TC Lights on & Speedo not working -3.0 Elite  (Read 1667 times)
davesink
  • Edinburgh
    • 2.6 MV6 Saloon
« on: 12 January 2009, 21:51:38 »
Picking up my first omega tomorrow night (99 Estate)
ABS & TC lights on & speedo does not work. Will check and clean all ABS sensors, if that does not do the trick ABS ECU problem ?
Who in the Edinburgh area could offer advice (Tech2??)
Re: ABS & TC Lights on & Speedo not working -3.0 Elite
« Reply #1 on: 12 January 2009, 21:52:50 »
ABS ecu is the likely cause, they can be refurbed for just over a 100 quid.
« Reply #2 on: 12 January 2009, 21:53:23 »
Will more than likely if not a broken sensor be the ECU mate. There is a how to on the maintainence section  :y
« Reply #4 on: 12 January 2009, 21:54:01 »
Sensor failure is VERY rare on the Omega
« Reply #5 on: 12 January 2009, 21:54:54 »
Give "BBA Reman" a ring on 01634 687222 .. they'll give you a price ... and they do an excellent job  :y :y :y :y
« Reply #6 on: 12 January 2009, 21:55:26 »
There good but, a little over priced in my book.
« Reply #7 on: 12 January 2009, 21:55:52 »
I meant the wire (missed that bit out) on the sensor  :y
« Reply #8 on: 12 January 2009, 21:57:47 »
£130 and a 5 day turn around, including courier return and 3 year warranty ... :)
Ok that was 15 months ago but compare to £700m from the stealers I was well happy !!!
davesink
  • Edinburgh
    • 2.6 MV6 Saloon
« Reply #9 on: 12 January 2009, 21:58:44 »
Cheers guys - once I replace the abs ecu do I need to get the system set up again (the magic Tech2 offerduffer)
« Reply #10 on: 12 January 2009, 21:59:58 »
No, they refrub your unit so no re-config required!
« Reply #11 on: 12 January 2009, 22:01:13 »
If you have your existing ECU repaired  .. it just goes straight back on no problem.
A replacement ....  2nd hand/scrappy ..... must come from the same model/engine/model year variant ... (same part number essential) .. if it doesn't (Vx  spare)  it needs a tech 2 to set it up I believe
« Last Edit: 12 January 2009, 22:02:20 by entwood »
davesink
  • Edinburgh
    • 2.6 MV6 Saloon
« Reply #12 on: 12 January 2009, 22:02:32 »
thanks guys - i think i am gettin drawn in the mad world of omegas...
« Reply #13 on: 12 January 2009, 22:03:06 »
even then, if its not right part, may not be any good.
« Reply #14 on: 12 January 2009, 22:22:28 »
If you go second hand route you need same part nş (sensibly placed underneath ecu!!), and preferably off same year and model spec. as yours- expect to pay £40-£45.  Went this route on Estate - worked ok for me, didn't need Tech2.
