Author Topic: Creamy Oil Filler Pipe....  (Read 3353 times)
V6CDBOY
  • Wiltshire
« on: 11 January 2009, 10:02:25 »
Hi
Just he cheked the oil level on the miggy and opened the filler cap which is covered in a creamy substence?
Can I just clean it off and does this indicated an underlying problem?
Help!!!
Andyb
  • Lincoln
Re: Creamy Oil Filler Pipe....
« Reply #1 on: 11 January 2009, 10:04:04 »
norm m8 if u do short trips the engine dont get hot enough to clean it off its is also made worse but different makes of oil
« Last Edit: 11 January 2009, 10:04:31 by thelofty »
V6CDBOY
  • Wiltshire
« Reply #2 on: 11 January 2009, 10:13:31 »
Thanks Andy B
Just on my last car the garage said that this was a classic sign of Head Gasket failiure??
« Reply #3 on: 11 January 2009, 10:33:07 »
i'd guess short journeys and shitty oil.  v6 hg does not fail like that, in fact the v6 hg very, very rarely fails.
do be concerned, though, as your breathers will be in same state, and thats bad news.....
V6CDBOY
  • Wiltshire
« Reply #4 on: 11 January 2009, 10:39:11 »
So do you recommend oil change and long journey
 :D
jjleonard
  • stevenage
« Reply #5 on: 11 January 2009, 10:53:08 »
Recommend cleaning the mayo off the filler cap, do a breather clean out, THEN change the oil.
A good blast up the motorway wouldn't hurt, either!
Breather clean out guide is here: http://www.omegaowners.com/forum/YaBB.pl?num=1152598350
V6CDBOY
  • Wiltshire
« Reply #6 on: 11 January 2009, 15:04:15 »
So if I need to clean the breathers I need to remove the plenum.  Is this a job for a non-mechanic type person like myself? If not can anyone recomend a good garage in the Wiltshire area that could do this for me???
 :D
jjleonard
  • stevenage
« Reply #7 on: 11 January 2009, 15:11:31 »
Yes - removing the plenum is a simple job to do, with minimal tools. I did it without any mechanical experience and just a halfords toolkit - I went on to do the camcover gaskets and the cambelt too!
Just take it carefully and slowly, noting the connections to it as you go. The only bit that is fiddly is the breather box at the rear of the engine, drivers side.
A detailed guide to getting the plenum off is here: http://www.omegaowners.com/forum/YaBB.pl?num=1176213776
« Reply #8 on: 11 January 2009, 15:48:07 »
Breather clean is not that difficult ... allow a couple of hours max... whereabouts in Wiltshire are you ??? I may be able to assist ???
V6CDBOY
  • Wiltshire
« Reply #9 on: 11 January 2009, 15:52:41 »
Hi Entwood
I'm in Devizes!!
« Reply #10 on: 11 January 2009, 16:13:25 »
Not too far I'm only Swindon area... due to work it would have to be a weekend, and I'm away the next 2 ... but if I can help after that just yell.
If you read/print the guides
http://www.omegaowners.com/forum/YaBB.pl?num=1159298765
and
you'll find it is a lot easier than you suspect .. :)
« Last Edit: 11 January 2009, 16:14:16 by entwood »
V6CDBOY
  • Wiltshire
« Reply #11 on: 11 January 2009, 16:19:39 »
Cheers Mate Will Do.
« Reply #12 on: 11 January 2009, 18:28:03 »
Vx oil does seem to be less prone to the mayo effect than other oils, particularly that crappy castrol shite!
From memory, Entwood has a TC card, so may be able to assist in getting genuine parts at very good prices.  If not, others in Swindon area have Trade Club.
« Reply #13 on: 11 January 2009, 18:29:12 »
You will need some Torx tools, as most manufacturers use torx now
« Reply #14 on: 11 January 2009, 19:28:55 »
As said .. I have the required gubbinses ... toolbox and TC .. if you need my help and let me know any parts I'm sure I can do the business  :y :y
