Author Topic: 2000 Elite auto probs  (Read 1685 times)
mikemcq
« on: 12 January 2009, 23:04:02 »
Hi first question hope someone can help 2000 Elite auto 2.5 with autobox probs I select D from standstill and the car is in 2or 3 still pulls off but loads of revs needed. Put it in 1 manually and she pulls away fine then once in D she drives as normal except wnen slowing to a stop when 1st is needed then its a case of remembering to put it in manually starting to be a pain also lost sport mode  any ideas ?
Re: 2000 Elite auto probs
« Reply #1 on: 12 January 2009, 23:09:47 »
ATF change and new filter first :y
« Reply #2 on: 12 January 2009, 23:11:29 »
"Automatic Gearbox" showing on MID :question :question
« Reply #3 on: 12 January 2009, 23:17:41 »
Thought I'd read this before - posted same issue under http://www.omegaowners.com/forum/YaBB.pl?num=1231760112
- two identical posts
« Reply #4 on: 12 January 2009, 23:19:33 »
You are correct dbug ::)
« Reply #5 on: 12 January 2009, 23:21:17 »
How strange (or just impatient :() - as you say change ATF and clean filter first.
« Reply #6 on: 12 January 2009, 23:23:16 »
Newbie just trying to find his way round I suppose ;)
« Reply #7 on: 13 January 2009, 00:42:02 »
Something funny going on here, unless i have miss read the times posted, the other thread(in the link)
is the one i was replying to when the site crashed earlier, yet the the time of post says 11.35? Wtf?
Edited, no its me, 11.35 a.m. Sorry.
« Last Edit: 13 January 2009, 00:45:16 by chrisgixer »
mikemcq
« Reply #8 on: 13 January 2009, 14:17:07 »
Yeh your right newbie finding his way around, as for question thanks for replys but atf and filter changed about  3000 miles ago
mikemcq
« Reply #9 on: 13 January 2009, 14:20:12 »
Thanks ATF and filter changed recently and yes Automatic Gearbox is showing
« Reply #10 on: 13 January 2009, 21:20:31 »
Are the gear selector lights acting up. ie do they flash or are all or some of them illuminated  :question
unlucky alf
  • worksop, notts
« Reply #11 on: 13 January 2009, 21:31:40 »
have you changed the battery or had it in & out?, just wondered if you might have knocked the round plug loose by the battery tray, there are 3 of them & the g/box one is the middle one [colour coded blue],check it for dampness, is the g/box warning coming up before you start the engine?, could also check the connector clipped on the g/box [rectangular one], i wont say what it was on mine cos apparently they never go ;D ;D ;D
mikemcq
« Reply #12 on: 14 January 2009, 15:15:33 »
Thanks for that yes battery as been replaced recently so will check that plug  cheers
mikemcq
« Reply #13 on: 14 January 2009, 15:16:56 »
Yeh they all light up as they should cheers
