Author Topic: fault codes  (Read 1523 times)
Omega Pixie
  • Yorkshire
fault codes
« on: 15 January 2009, 10:32:43 »
Do you have to clear the fault codes do thay remain on the system unless cleared by tecII. Thanks for all your help
SP_3.2
  • Leicester
    • drives A6 allroad 3.0tdi
Re: fault codes
« Reply #1 on: 15 January 2009, 10:55:16 »
They should clear after 20 or so clean starts. Can be cleared with a Tech 2 or a cheap Scanner/ code reader.
Hope that helps.
Re: fault codes
« Reply #2 on: 15 January 2009, 11:43:45 »
but if your EML is still on, you still have a fault.  :y
Omega Pixie
  • Yorkshire
Re: fault codes
« Reply #3 on: 15 January 2009, 11:49:02 »
i have no eml light on but engine misfires thanks for the help
