Author Topic: steering play  (Read 997 times)
ianboyo
  • Somerset
steering play
« on: 15 January 2009, 21:40:00 »
i have steering colume play seems thought its coming from the top have checked road wheels ect for play in rack that is fine has anyone had any problem from play top end of steering colume any help would be greatful the car is 2.5 omega v6
« Last Edit: 15 January 2009, 21:41:02 by ianboyo »
Re: steering play
« Reply #1 on: 15 January 2009, 21:43:18 »
It's normal to feel some play at the steering wheel with the engine stopped. Once running, check there is no "lost motion" between steering wheel and track rod while gently rocking the steering wheel.
ianboyo
  • Somerset
Re: steering play
« Reply #2 on: 15 January 2009, 21:47:46 »
thanks kev, them you hold steering wheel at 9oclock and 3oclock there is alot of movement as if there is something worn maybe where the tilt steering part is are there any bushes there under the steering wheel that would cause play
quote author=416F7C6364555D65656E0A0 link=1232055600/1#1 date=1232055798]It's normal to feel some play at the steering wheel with the engine stopped. Once running, check there is no "lost motion" between steering wheel and track rod while gently rocking the steering wheel.
[/quote]
Re: steering play
« Reply #3 on: 15 January 2009, 22:38:34 »
Do you mean lateral movement of the steering wheel, or play in the rotation?
I would imagine there's a poly bush or two that support the column which could wear and cause lateral play. Not had the column apart, I'm afraid. :-/
Re: steering play
« Reply #4 on: 16 January 2009, 07:54:05 »
both my omegas have had play/rocking in the column, never seemed to get any worse, and as Kevin says, with engine off play between steering wheel and road wheels, this slack is taken up when engine on althoug there is an adjustment on the steering box, but thats a last report really.
 If your having trouble keeping the car in a straight line, first place to look is wishbone bushes on the front and donut bushes as the back. Then steering idler/track rod ends. Hth
Edit, never had the colum apart but have seen talk one here re a poly bush or similar. Worth a search...
« Last Edit: 16 January 2009, 08:05:03 by chrisgixer »
