Author Topic: Airbag Light  (Read 1117 times)
PaulW
  • Somewhere near Manchester
  • Come on you fiend!
    • Some crappy Insignia
Airbag Light
« on: 16 January 2009, 14:23:45 »
Is there a common issue which can make this come on?
The light in the Estate is lit.  Ignition on, Airbag light is on.  Start engine, it goes out, and about 1 second later, it comes back on...
I can't read the codes, as have no code reader...
Anything worth checking??  Cheers
Humbugs...
Re: Airbag Light
« Reply #1 on: 16 January 2009, 14:43:11 »
IIRC, Once the airbag light is on it needs to be reset with tech2.
Re: Airbag Light
« Reply #2 on: 16 January 2009, 14:43:57 »
Could be many things.....needs the codes reading ideally
PaulW
Re: Airbag Light
« Reply #3 on: 16 January 2009, 14:45:24 »
Well it's not a major concern for now, not like it will fail its MOT with it on...
I've had the airbag light come on a few times on the Elite too, but it goes out when I stop & restart the engine...  Only happened when we had the real cold weather, its fine now...
Humbugs...
Re: Airbag Light
« Reply #4 on: 16 January 2009, 14:59:03 »
Depends on the fault, and the ecu type ime
vrba
  • Croatia
Re: Airbag Light
« Reply #5 on: 16 January 2009, 15:27:09 »
sorry for off topic but have a q about the airbag unit.
i know that my '97 have diferent airbags than '94 cause i have put in mine that '94 bag but the jack is different, so i need to know is the main unit the same, i'v bought passanger airbag and main unit from '94. and if that airbag can be connectd somehow to my car
