Author Topic: Coil pack replacement  (Read 1023 times)
trinity0_10
  • Norfolk
« on: 16 January 2009, 15:14:20 »
After going out today the car felt as if it was on rumble strips over 50. It was the same on gas or petrol so I think the coil pack is a possibility. It was especially teeth jarring when accelerating. Cruising was not too bad and under 50 was reasonable.
Any advice or help for replacing the coil pack on a 2.5 V6 would be of help.
Mike
Omega Elite 1999 2.5 saloon LPG
Vectra SRi 1998 2.0 Estate LPG
vrba
  • Croatia
Re: Coil pack replacement
« Reply #1 on: 16 January 2009, 15:20:51 »
by coil pack i presume you think on dis pack, there is somewhere "how to", try to do a search. i think that its a little tricky to get to cause it stands behind the engine.
« Reply #2 on: 16 January 2009, 16:35:24 »
Though there is a good chance it is, do a paperclip test first, to see if engine thinks anything is wrong.  Also worth checking plugwells for oil
