Author Topic: Handbrake Light...  (Read 1182 times)
Mr Hagon
  • South West London
  • RWD and V6; the only way to travel!
Handbrake Light...
« on: 16 January 2009, 11:49:00 »
...doesn't go out when I take the handbrake off.  Doesn't cause an issue and the car drives normally.
When I put the handbrake on I need to pull it up all the way.
So, is this a simple case of readjusting the handbrake cable so the handbrake doesn't come up so high, or could there be something more sinister at work.
Mark
Vauxhall Omega Elite 3.2 Estate (Mar '02) in Star Silver.
Re: Handbrake Light...
« Reply #1 on: 16 January 2009, 11:53:13 »
Check the brake fluid level.....if low, this will also put the brake warning light on.
As for the handbrake, a good service will do it good!
Mr Hagon
  • South West London
« Reply #2 on: 16 January 2009, 21:59:32 »
Yup, brake fluid level.  Quick top up and light goes out.
Cheers,
Mark
Dazzler
  • Haverhill, Suffolk
« Reply #3 on: 16 January 2009, 22:02:23 »
You should still get your handbrake sorted out if its very high as it will not hold properly sooner or later.
« Reply #4 on: 16 January 2009, 22:17:34 »
low brake fluid can be a sign of low pads somewhere. Or a leak.
r1
  • nottingham
« Reply #5 on: 17 January 2009, 09:57:12 »
took mine for the mot failed on handbrake,garge said some springs were missing quoted 20 quid so i said ok.now the hand brake comes right up and doesnt feel as good
Mr Hagon
  • South West London
« Reply #6 on: 17 January 2009, 16:26:03 »
Going in for MOT and service in two weeks so will have handbrake adjusted...
Front discs and pads were done a while ago but the Omega barely does 6k a year.  Having topped up the brake fluid I should know if the leak is bad if the light comes on again before the service.
Mark
