Author Topic: Engine cutting out while driving  (Read 2452 times)
Tony_1985
  • Ellesmere Port, Cheshire
« on: 18 January 2009, 21:55:47 »
Started having this problem today.
Whilst driving the car it starts to cut out, this can be at any revs in any gear. It also does it while idling
It eventually goes to the point of stalling, and taking a long time to restart.
I'm going down the lines of doing the IACV and breather pipe clean tomorrow.
Is there anything else I should look out for?
The engine management light is NOT on
This is a 96 Omega 2.0 Auto
« Last Edit: 18 January 2009, 21:56:26 by Tony1985 »
Re: Engine cutting out while driving
« Reply #1 on: 18 January 2009, 22:00:46 »
if icv, won't stall at higher revs, only idle
hotel21
  • The Kingdom of Fife
« Reply #2 on: 18 January 2009, 22:03:04 »
Also think fuel starvation...  When was the filter last changed??  Fuel pump cutting out?
omegalad
« Reply #3 on: 18 January 2009, 22:15:38 »
Same things happening to my car taking a fuel pressure test tommrow and cleaning ICV and checking pipes.
driving me nuts.
who does a good tech2 ? to localise the problem? wouldnt trust vx as far as i could throw em.
« Reply #4 on: 18 January 2009, 22:15:46 »
Any fault codes ?
omegalad
« Reply #5 on: 18 January 2009, 22:24:03 »
yes fuel trim 0170  -- could be anything too many parts to replace.
02 sensor replaced
MAF  replaced
vx cleaned ICV but i dont think they did it properly.
 could be crank sensor or fuel pump
whats the egr?
hotel21
« Reply #6 on: 18 January 2009, 22:28:24 »
Exhaust Gas Recirculation (valve)
Tony_1985
« Reply #7 on: 19 January 2009, 02:03:54 »
Going to have a good look at it tomorrow, make sure everything is connected as it should be
IACV is being done anyway, as are the breathers
Think its time for the paper clip test
Page created in 0.026 seconds with 16 queries.
