Author Topic: NOW what??  (Read 1607 times)
Leomas
  • Boyne Valley (on loan)
  • Ooops what did I break this time?
NOW what??
« on: 19 January 2009, 17:45:35 »
There was me thinking I had finally been a good boy and found gearbox and someone to fit it for me.......
Box is in and it drives OK but apparently there is a fault code coming up of P730B. Was told there are a variety of possible causes but before I get into hassling the people that I got the gearbox from is there anything I should be worried about? Don't want to put lots of effort to talk them into paying for remedial work if it is more likely that I have to replace the box.
It's a T Reg 2.5V6 auto and I am 'assured' that it is the right gearbox but it arrived with the torque converter dismounted (didn't see it myself as I had it delivered direct to the gys doing the work)
Recently 'learned up' and being more careful now, honestly.
Ummm except for where I fix one thing and break something else
Re: NOW what??
« Reply #1 on: 19 January 2009, 18:24:31 »
P0730 is Gear Ratio incorrect.  Assuming its not an old code, it means excessive slip in box for at least 2.5s at 3.5k rpm or higher.
Leomas
Re: NOW what??
« Reply #2 on: 19 January 2009, 18:57:53 »
Is there a simple way to flush out any old codes?  Oh, and is it a Tech2 type job (or whatever that magic box is) to search for new ones?
Become quite an expert at the paperclip job, just wondered if there was an equivalent
« Last Edit: 19 January 2009, 18:58:32 by Leomas »
Re: NOW what??
« Reply #3 on: 19 January 2009, 21:04:34 »
A good code reader needed to clear codes, and check for new ones
Page created in 0.028 seconds with 16 queries.
