Author Topic: Mayo in cap  (Read 1658 times)
Kaycee
  • Doncaster
Mayo in cap
« on: 19 January 2009, 13:19:08 »
Just checked my oil filler and the tube is full of the dreaded mayo ad the car serviced just before Xmas i also told him to clean breathers which he said he did i also asked if he put genuine VX oil in and he said no but the semi synthectic he put in was just as good my old CDX 2.5 never had mayo at anytime but this 3.2 as it in every time i check
1 Could it be the oil
2 Could it be breathers not done right
3 Is it because it no longer as the EGR valve as with the engine running and the cap of there is slight smoke coming out of filler
it does not seem to use any oil
i seem to think i read somewhere about useing VX Oil
thanks
There is a tide in the affairs of man if taken at the flood will lead on to greater things
Re: Mayo in cap
« Reply #1 on: 19 January 2009, 13:24:20 »
Short journeys?
Some oils, particularly the Castrol crap, are more prone than the genuine Vx oil...
Chances are, whatever happens in cap, chances are similar will start happening in breather system...
Kaycee
  • Doncaster
Re: Mayo in cap
« Reply #2 on: 19 January 2009, 13:38:48 »
Thanks TB yes i have been doing some short journeys recently
Robert
Danny
  • Wigan, Greater Manchester
Re: Mayo in cap
« Reply #3 on: 19 January 2009, 14:10:37 »
Robert
shouldnt be anything to worry about, more frequent longer journeys with the engine getting to optimum heat, the mayo should clear
Bojan
  • Croatia, Slavonski Brod
    • MV6 3.0
Re: Mayo in cap
« Reply #4 on: 19 January 2009, 14:41:25 »
Is the oil filler neck installed? If so, then remove it...
I've done that, and put the oil filler cap directly on cam cover, and have no mayo anymore.
Oil filler neck is in the boot, and when filling up with oil, I just install it...
Re: Mayo in cap
« Reply #5 on: 19 January 2009, 19:12:53 »
when you say "full" do you mean solid mayo, or just on the wall of the filler neck/on the cap?
Kaycee
  • Doncaster
Re: Mayo in cap
« Reply #6 on: 19 January 2009, 20:52:08 »
no just a coating around the neck can wipe with a tissue and all gone
Re: Mayo in cap
« Reply #7 on: 20 January 2009, 01:07:36 »
normal mate  :)
Kaycee
  • Doncaster
Re: Mayo in cap
« Reply #8 on: 20 January 2009, 08:00:55 »
thanks mate
thought ide got major probs
Page created in 0.197 seconds with 16 queries.
