Author Topic: door trim  (Read 1310 times)
bighed
  • Shropshire
door trim
« on: 21 January 2009, 13:18:31 »
Have just give my mig a quick rinse and noticed that the read door trim has caught on the front one when shutting and bent it back. Is this an easy fix? How does trim come off?  :y
Re: door trim
« Reply #1 on: 21 January 2009, 13:23:23 »
vauxfan2k
  • Western Isles
Re: door trim
« Reply #2 on: 21 January 2009, 13:23:39 »
the plastic part is glued to a metal backing, which is then held onto the car by double sided trim tape and a couple of plastic clips. its almost impossible to get one off without knackering it, if you plan to get a second hand one so that the finish matches your other one, then Use a hairdryer to warm the ouble sided tape before you remove it.  :y
