Author Topic: Suspension woes  (Read 4506 times)
nixoro
  • Hitchin, Herts
Suspension woes
« on: 19 January 2009, 21:30:02 »
Just lately been getting a swaying feeeling as in a boat when motoring along every bump the car rocks now I'm guessing my shocks are shot at the front or all round maybe.
I have also noticed the front end has dropped slightly whats the chances its just spring related.
Any help on this would be greatly appreciated as I am thinking to replace the shock all round come the end of the month including the wishbones and anti roll bars.
What I dont get is it passed the MOT with just a failure on the exhaust which was blowing surely the suspension would have been tested.
« Last Edit: 19 January 2009, 21:31:22 by nixoro »
Re: Suspension woes
« Reply #1 on: 19 January 2009, 21:39:31 »
Failed shocks are not a fail, only leaking shocks
nixoro
  • Hitchin, Herts
Re: Suspension woes
« Reply #2 on: 19 January 2009, 21:44:15 »
Does this sound like the end of my shocks or could this be spring related
Have to admit this is looking to be why I hit a speed hump a while back.
More noticable since travelling further for work.
Whats the signs of failing shocks as they seem to settle again when bounced any other tests?
Re: Suspension woes
« Reply #3 on: 19 January 2009, 21:59:40 »
The bounce test is the right test.
nixoro
  • Hitchin, Herts
Re: Suspension woes
« Reply #4 on: 19 January 2009, 22:03:01 »
Thinking I will be going down the road of fitting new shocks all round.
I have just been looking on here and can only see a guide for rear shock removal.
If someone has done the front shock removal can you give me some pointers.
All the help I can get would be greatly appreciated.
Re: Suspension woes
« Reply #5 on: 19 January 2009, 22:04:42 »
Front is straightforward, but need spring compressors and get the camber reset afterwards.
I have to change some front springs, so will do a guide at same time, but depends when I get time to do it...
tmx
  • Herefordshire
    • 3.2 MV6 2002
Re: Suspension woes
« Reply #6 on: 19 January 2009, 22:05:01 »
my MV6s were leaking so i replaced them both! my car just bounced about when i went over speed humps both front ones were leaking at 122k
whilst replacing them i noticed my WB bushes were all nackered so i replaced the wishbones aswell!
replacing the struts is fairly easy to do on the omega hardest part is compressing the spring!
FAO The Boy ive got pix from when i changed myn but dont have the free time atm to write a guide
« Last Edit: 19 January 2009, 22:06:58 by tmx »
nixoro
  • Hitchin, Herts
Re: Suspension woes
« Reply #7 on: 19 January 2009, 22:15:59 »
Thought I might need a set my local motor factors do them for £32 does this sound pricey?
nixoro
  • Hitchin, Herts
Re: Suspension woes
« Reply #8 on: 19 January 2009, 22:17:46 »
Any pictures would be a great help :y
nixoro
  • Hitchin, Herts
Re: Suspension woes
« Reply #9 on: 19 January 2009, 22:20:33 »
I got a quote from my local motor factors and they quoted me £180 roughly all in for front and rear shocks does this sound a fair price.
Geometry last time I had it done wasn't to pricey but a reminder of how much this usually cost would be a bonus.
Was thinking to get a garage to do all the work but there is no fun in that :)
tmx
  • Herefordshire
    • 3.2 MV6 2002
Re: Suspension woes
« Reply #10 on: 19 January 2009, 22:43:48 »
get Genuine GM ones at the end of the day genuine suspension parts wont compromise the cars handling find a member near you with a Vauxhall Trade card
nixoro
  • Hitchin, Herts
Re: Suspension woes
« Reply #11 on: 22 January 2009, 18:47:36 »
How much would these be if bought through trade card option?
Re: Suspension woes
« Reply #12 on: 22 January 2009, 18:54:04 »
other hints for finished shocks:
abs will become active frequently..
some irregular noises from shocks ..
when turning curves the car will tilt more than normal on sides..
nixoro
  • Hitchin, Herts
Re: Suspension woes
« Reply #13 on: 22 January 2009, 19:00:47 »
Well the car at the moment when driven you feel like your on a boat rocks side to side when doing 30-50 anything above that its not so noticable.
Thinking about in cold weather when going over speed humps just up the road you hear a creaking noise, I thought it was the wishbones but thinking about it, could well be the shocks :-/
Have to admit the back end was a little twitchy when turning in places.
The brakes though so far have been ok.
« Last Edit: 22 January 2009, 19:02:31 by nixoro »
hotel21
  • The Kingdom of Fife
Re: Suspension woes
« Reply #14 on: 22 January 2009, 21:00:28 »
Genuine VX front shocks are about £50 each plus vat and the rears vary between £50 and £70 each, again plus vat, according to an old photocopy TC listing I have.  Actual cost varies between car varients....  :y
