Author Topic: no power to fuel pump  (Read 1989 times)
gibbo
« on: 22 January 2009, 19:09:46 »
I have no power to the fuel pump when it is on the car the pump itself is working.  I am checking the relay, if that is ok does anyone know what the problem could be? Could it be the wiring?
markey mark
  • SLady bitshorpe north lincs
Re: no power to fuel pump
« Reply #1 on: 22 January 2009, 19:13:09 »
in all the years i have been messing with omegas never heard of wireing to pump fail or relays fail  :-/ :-/
vauxfan2k
  • Western Isles
« Reply #2 on: 22 January 2009, 19:14:46 »
what symptoms are you having that makes you think the pump isnt getting any power?
« Reply #3 on: 22 January 2009, 19:17:14 »
Read the fault codes.....the V6 fuel pump on fires when the engine is cranking......and to detect the engine is cranking requires a working crank sensor
gibbo
« Reply #4 on: 22 January 2009, 19:24:37 »
What I have done to check the fuel pump is connect two wires from the battery to the pump the pump then works.  If I put the original wiring back on the fuel pump  it does not work, and does not pump fuel this is why I thought it was a wiring problem or relay problem, not had an Omega before.  I know its a fuel problem because I had the pump working with direct wires from the battery to it, the car then runs.  Once I have got it running its works for a couple of days then gives up again, its like it has some kind of loose connection. :(
markey mark
« Reply #5 on: 22 January 2009, 19:31:09 »
crank sensor matey ! paperclip test and you will have code 19 check maintence section  :y
gibbo
« Reply #6 on: 22 January 2009, 21:16:20 »
Cheers mate know this is cheeky but where do I find the crank sensor!!
hotel21
  • The Kingdom of Fife
« Reply #7 on: 22 January 2009, 21:20:17 »
On a V6....
http://images.omegaowners.com/images/guides/cranksensor_location/crank_sensor_engine_number_alt.JPG
