Author Topic: what heads on 2.6 ??  (Read 6275 times)
markey mark
  • SLady bitshorpe north lincs
« on: 22 January 2009, 15:19:32 »
right chaps got a 2.6 to rebuild after cambelt failure !! which heads would work better 2.5 or 3.0 ?? tia  :y
Re: what heads on 2.6 ??
« Reply #1 on: 22 January 2009, 15:20:31 »
Late (post 98) 2.5 heads are the same I am told....
markey mark
« Reply #2 on: 22 January 2009, 15:23:28 »
cheers mark ! so would 3.0 heads be any detrement to it its just i have a set of recon ones with all new valves and they have been skimmed  :-/
« Reply #3 on: 22 January 2009, 15:30:07 »
They would lower the compression ratio.....
They need to be post 98 heads as these have the extra casting sections with tapped holes to support the DIS packs.
markey mark
« Reply #4 on: 22 January 2009, 15:42:55 »
dont suppose you know how much ?? would it have much effect on power ??  :-/
« Reply #5 on: 22 January 2009, 15:55:33 »
According to my calcs, it would take it from 10:1 down to 8.36:1
Thats a big drop and would affect performance and economy
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
« Reply #6 on: 22 January 2009, 17:48:37 »
i can try and find out if my 2.5 heads are post 98 if you want mark?
V8!!!!
markey mark
« Reply #7 on: 22 January 2009, 18:41:25 »
if you could alex ta mate  :y
markey mark
« Reply #8 on: 22 January 2009, 18:42:10 »
thats a very big drop mark ! would be ok if i was putting a turbo on it !
ngrainqey
  • rotherham
« Reply #9 on: 22 January 2009, 18:45:31 »
lol hence why i bought my 3.0 heads for my 2.5 bottom end haha!
*edit-can somebody send me a pic of what to look for on post 98 heads so i can tell it mine are post or pre 98
thanks
« Last Edit: 22 January 2009, 18:46:27 by grainqey »
V8!!!!
markey mark
« Reply #10 on: 22 January 2009, 18:51:32 »
alex send me a pic to my mobile of the top of the head were the spark plugs go mate  :y
ngrainqey
  • rotherham
« Reply #11 on: 22 January 2009, 18:55:42 »
right okie dokie mark, it might be tonight (but probably tomorrow when i can get pics)
also... i thought it was just the camcovers that stopped you using the coil per plug ignition rather than the heads too  :-/
V8!!!!
markey mark
« Reply #12 on: 22 January 2009, 19:00:33 »
no mate in the alloy around the spark plugs there is tapped holes to bolt the coilpacks down mate  :y
ngrainqey
  • rotherham
« Reply #13 on: 22 January 2009, 19:05:35 »
oh... those stupid things!
i'll have a look tonight or tomorrow (doubt it'll have them tbh)
why not just not both with the little torx bolts? the seemed like right little barstuards to pull off/out so dont imagine they would "NEED" them imo
V8!!!!
ngrainqey
  • rotherham
« Reply #14 on: 22 January 2009, 22:55:51 »
had a look at my 2.5 heads mark and they dont have the two bolt holes for the coil per plugs :(
V8!!!!
