Author Topic: TD Stat and water pump  (Read 1491 times)
MickAP
  • South Derbyshire
« on: 21 January 2009, 15:23:55 »
How long would it take to replace the stat and water pump on the TD engine
Reason for asking is I don't fancy doing it myself and just want to get a rough idea on possible costs/time labour wise from someone who has replaced theirs.
Infact the pump should be ok but because the stat needs replacing may as well do the pump as well, what do you think?
Mick
Omegatoy
  • UK
Re: TD Stat and water pump
« Reply #1 on: 21 January 2009, 17:41:56 »
both together shouldnt take more than an hour and a half, BUT!!! they could make it longer by saying they had trouble removing viscous and we had  to drain rad remove rad etc etc,
ive never had to remove the rad to do stat , or water pump or the alternator belt :y
charlie
  • sunderland
« Reply #2 on: 21 January 2009, 17:58:55 »
done the stat didnt take that long if you buy a stat without a seal i have one here. min order was 2??? i will post it if you want it might save you a trip to vx ps halfords stat was only a £10
« Reply #3 on: 21 January 2009, 18:15:41 »
If the stupid viscous fan comes off straight away, or like me you keep it in the garage where it belongs, about 1hr, bit longer if you take the opportunity to change coolant (drain plug in block and on rad, so nice and easy)
MickAP
  • South Derbyshire
« Reply #4 on: 21 January 2009, 21:02:51 »
Left handed thread is this one?
« Reply #5 on: 21 January 2009, 21:05:56 »
yup. LH thread
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #6 on: 21 January 2009, 22:05:08 »
One and a half hours max to change both.
No need to remove rad either.
MickAP
  • South Derbyshire
« Reply #7 on: 22 January 2009, 15:31:09 »
And best place to get the correct parts, apart from paying dealer prices? That's stat and pump.
Mick
« Reply #8 on: 24 January 2009, 09:06:31 »
Mick
I used a large local factors in MK, Motorserv, but they don't really do mail order. Seem to recall stat being around a tenner, but pump really expensive.
