Author Topic: non starter !  (Read 787 times)
daz1420
  • york north yorksire
non starter !
« on: 24 January 2009, 19:20:12 »
i did a really silly think i took my ecu out (99s 2.5d) to look at the id number on it and dropped it and it fell on the posative lead of the the battery  >:( and now its turning other but will not start up ive looked at the fuses where the ecu is and under the steering wheel but cant see any blown  :( is the fuel pump fuse situated some where else please help DAZ  :y
vauxfan2k
  • Western Isles
Re: non starter !
« Reply #1 on: 24 January 2009, 19:24:47 »
cant help with the fuse/relay locatons as my tractor is on its way to car heaven, but if the worst happens and you need another ecu, i kept mine along with the 2 chips for the keys and the barell reader, if you need it.
good luck  :y
daz1420
Re: non starter !
« Reply #2 on: 24 January 2009, 19:33:00 »
good luck  :y
cheers matey hopefully it dont come to that but shall get in touch if i need that DAZ  :)
daz1420
Re: non starter !
« Reply #3 on: 25 January 2009, 16:24:38 »
good luck  :y
ive had a good look today no power to fuel pump or cold start ,cracked an injector pipe no fuel to injectors so assuming no power to injector pump all the fuses look ok tryed doing paper clip test but did not even get ecu light on the dash on  :-[ i thing ive fryed the ecu  :'( any think else i can check dont thing its the imoberliser as it makes all the right beeps when opening the doors +the ignition lights come on and she turns other ok !!  :-/ DAZ
