Author Topic: Nackered V6 Engine?  (Read 1725 times)
tmx
  • Herefordshire
    • 3.2 MV6 2002
Nackered V6 Engine?
« on: 25 January 2009, 18:21:29 »
Just changed my ignition coil plugs and leads
anyway all 6x of my plugs are black is my engine nearing the end of its life?
its a 3.0 Later type 98 on V6 engine with 123k had a full rebuild at 97k as the belt snapped killing 1 piston and conrod
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
Re: Nackered V6 Engine?
« Reply #1 on: 25 January 2009, 18:22:57 »
it might just not be burning the petrol fully so charcoaling the plugs a bit
V8!!!!
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #2 on: 25 January 2009, 18:24:00 »
that would be the timing then wouldnt it?
ngrainqey
  • rotherham
« Reply #3 on: 25 January 2009, 18:26:26 »
possibly yeah, im not sure though so you'd be better askin or looking in the back of the haynes manual as it gives descriptions and stuff for how the plugs look :y
V8!!!!
MutantCav
  • Gainsborough
« Reply #4 on: 25 January 2009, 18:26:30 »
I presume you had a misfire to change them all in the first place?
Might just be the misfire causing it and could be fine now you have changed it all assuming the problems gone away??
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #5 on: 25 January 2009, 18:28:48 »
aye it missfired on full beanz and when towing heavy trailers
also missfired on tickover when hot
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #6 on: 25 January 2009, 18:41:04 »
Do you have any codes?
« Reply #7 on: 25 January 2009, 18:44:08 »
Fear not, the plugs will foul quite quickly if used for a short journey or even after moving the car to do work on it!
Ian_D
  • York
« Reply #8 on: 26 January 2009, 00:03:11 »
Ive never seen a spark plug yet that looks like the 'Normal' ones in the haynes books! There all usually a fair bit more black! I would only be worried if its covered in oil tbh!
[size=12]
