Author Topic: Help-engine electrics warning light on  (Read 1542 times)
jerry
« on: 25 January 2009, 22:12:35 »
wonder if anyone can offer any advice. Was just driving home and car fine but when I put it in sports mode to help overtake the engine  electrics light came on. Took sports mode off and drove home steadily and she seemed fine. Recently had new oil cooler and aux belt and tensioner. Its a 2.5 v6 auto. Any ideas on what its likely to be or else how to access fault codes. Will get it in to garage Tues hopefully, but will it be ok to drive tommorrow (25 mile run to work)?
                                            thanks jerry :-/
tmx
  • Herefordshire
    • 3.2 MV6 2002
Re: Help-engine electrics warning light on
« Reply #1 on: 25 January 2009, 22:14:32 »
try the paperclip test search the how to part of the forum and you will find it its a very easy test to do
then post up the error code and we will be able to help you
« Last Edit: 25 January 2009, 22:15:32 by tmx »
jerry
« Reply #3 on: 25 January 2009, 22:25:30 »
Thanks tmx/Pete, will try in morning and post code then.(good link by the Boy by the way-even I could understand it!). Heres hoping its nothing too serious,
                                                      jerry :y
jerry
« Reply #4 on: 26 January 2009, 09:42:44 »
Right, done the paperclip test and got:
12(START DIAG)
59?
31(no rpm)
12
So can anyone tell me what code 59 is and is it going to be ok for me to use the car today before I can get it in to garage tommorrow? Thanks guys,
                                                          jerry
« Reply #5 on: 26 January 2009, 09:49:40 »
12(START DIAG)
59?
31(no rpm)
12
                                                          jerry
59 = Intake manifold valve low---- Check connector at rear of multi-ram passenger side. :y
31 = No RPM signal.  Paperclipped with engine not running :question
« Last Edit: 26 January 2009, 09:52:14 by RobG »
jerry
« Reply #6 on: 26 January 2009, 09:56:21 »
Cheers Rob,
Ive just found it on marks dtm post under tech info (should have looked harder before!), but wasnt 100% if applied to mine.All I have to do now is find out what that means and how much!!Thanks again Rob,
                                                   jerry :y
« Reply #7 on: 26 January 2009, 10:04:05 »
Check round the plenum area for any loose connections, trapped wires etc. Seeing as the oil cooler was done recently may be one of the aforementioned. If you `clipped it with the engine running 31 is the cam sensor :y
jerry
« Reply #8 on: 26 January 2009, 10:13:08 »
Did the test with engine off, hence code 31. I cant see any loose wires, or connections but tbo dont really know what im looking for! If , during my fiddling I have corrected a problem with a loose connection would the warning light still stay on until cleared manually or should it go off? At the momment its still on. Sorry for my ignorance Rob,
        jerry
jerry
« Reply #9 on: 26 January 2009, 10:30:14 »
Found it!!(I think!),
Should look harder. Just checked with petes v6 layout post and, youre right Rob, there is a connection come off right at the back by the multiram.Didnt see it earlier. Only problem is with the size of my fingers and lack of tools is managing to get the bugger back on! If I cant get to do it, will car still be ok to use for today?
                                                               jerry
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #10 on: 26 January 2009, 15:14:07 »
the connector should go back in easily it is a one way type connector meaning theres a small nudge on one side and a clip on the other side that locks onto the plug
