Author Topic: V6 oil cooler removal  (Read 1687 times)
Chris_H
  • E London/Essex UK
    • Jag XF Portfolio S 3.0D
« on: 27 January 2009, 11:50:40 »
I'm trying to get to the oil cooler pipes by the filter to slacken them off.  I have the cartridge type oil filter and it's in the way.  Does it come off?  If so, how?
Haynes helpfully shows a canister type that doesn't obstruct access. Please?
First Vauxhall - PABX Cresta; Previous, previous Vauxhall - 3.0 12v Senator CD; Previous Vauxhall Omega Elite 3.0V6 Saloon Auto
Re: V6 oil cooler removal
« Reply #1 on: 27 January 2009, 11:52:37 »
Remove oil cap and filter.
Look inside the metal case and you will see a bolt that has either a large hex head or takes a torx insert.
Undo this and it lifts off.
Chris_H
  • E London/Essex UK
« Reply #2 on: 27 January 2009, 11:55:19 »
Thanks.  I'll give it a try.
I like the idea of looking inside it!  The car's on axle stands and even getting a mirror in is going to be tight.
ADDED LATER - 12mm hex for the record.
Thanks
« Last Edit: 27 January 2009, 12:25:23 by ChrisH174 »
Matchless
  • Nottingham
    • A white van
« Reply #3 on: 27 January 2009, 13:32:06 »
Dont use an open-ended spanner on the pipe unions, if they are tight (and they usually are) then you will distort the nuts.
You need to use a hex crows foot spanner or a flare nut spanner.
Chris_H
  • E London/Essex UK
« Reply #4 on: 27 January 2009, 13:41:28 »
Thanks for the tip.  I'll have to see about that one.
I'm wondering why they needed to stick an oil cooler in there in the first place!  It hardly seems good practice to feed the oil out of the block, back in, then out again, then back in again.  I know it will be a cool(er) spot but what a price. :)
