Author Topic: Rear demisters  (Read 3242 times)
Bumbazor
  • Worksop
Re: Rear demisters
« Reply #15 on: 27 January 2009, 20:01:56 »
No, didn't change looms but I'll be adding my own wiring to come on same time as something else. Not sure whether to link up to front blower or rear heated. All my button spaces are taken up too so it's the simplest solution other than adding another switch somewhere.
Carfix
  • Malmesbury, Wiltshire
    • 1997 & 1998 Omega Elites
Re: Rear demisters
« Reply #16 on: 27 January 2009, 20:35:20 »
I too have added rear demisters to my 99 CDX. I can confirm that the wiring is not there so I had to run my own. There was also no switch space in the centre consul switch bank so purchased a small rocker switch and LED from Maplins which I placed below the traction control switch to the left of the auto shiflt .
