Author Topic: Rear demisters  (Read 3243 times)
Bumbazor
  • Worksop
Rear demisters
« on: 26 January 2009, 19:04:21 »
Does anyone here have a pic of what the ducting looks like?
I'm retro-fitting to my car and so far have the motors in ok but now I need the ducting.
If not I can make some up as I think the outlet is from the round hole on the motor up to the door pin area. But what is there (if anything) for the inlet which is at the bottom of the door?
vauxfan2k
  • Western Isles
Re: Rear demisters
« Reply #1 on: 26 January 2009, 19:15:13 »
the air is sucked in thru the smaller opening on the motor casing, so no ducting for intake,
I have 2 ducts here in the garage that I can dig out to get a pic of, doubtfull you will be able to make something up as the space between door card and door is tight.
Bumbazor
  • Worksop
Re: Rear demisters
« Reply #2 on: 27 January 2009, 10:19:14 »
Ok a pic would be great, thanks.
Would you consider selling yours?
vauxfan2k
  • Western Isles
Re: Rear demisters
« Reply #3 on: 27 January 2009, 12:44:23 »
I would have done if I hadnt found a use for them in the estate car, anyone breaking a 95-96 elite on here should have them tho
will sort pics when I get home from work  :y
LFF64
  • HADDENHAM BUCKS
    • 64 insignia CT Nav 4x4
Re: Rear demisters
« Reply #4 on: 27 January 2009, 17:45:20 »
I would like to see a picture as well please . I have the ducting for inside the door and the fan unit but not sure how the air is taken in and out what do I need  :question
vauxfan2k
  • Western Isles
Re: Rear demisters
« Reply #5 on: 27 January 2009, 18:00:59 »
LFF64 if you have the ducting then the pic I will be taking is of no use to you, im only taking a pic of the actual ducting pipe for Bumbazor, not a pic of it installed. Not taking my door panel off just for a pic, sorry.
I wrote detailed instructions on fitting this kit a couple of weeks ago, have a search for rear demisters, it should come up.
cheers  :y
LFF64
  • HADDENHAM BUCKS
Re: Rear demisters
« Reply #6 on: 27 January 2009, 18:36:18 »
No problem  :y Any idea what it was called just tried rear demisters etc and could not see it  :question
vauxfan2k
  • Western Isles
Re: Rear demisters
« Reply #7 on: 27 January 2009, 18:41:05 »
cant remmeber the thread title, as my guide was a reply to someone elses thread. if I come across it Ill let you know  ;)
LFF64
  • HADDENHAM BUCKS
Re: Rear demisters
« Reply #8 on: 27 January 2009, 18:51:06 »
 :y I will have another look when I get a bit more time , I should be working really anyway  ::)
 I am really interested in holes in the door card if there are any ie how does the air get to the window  and where does the fan pull the air in from  :question :-/
Bumbazor
  • Worksop
Re: Rear demisters
« Reply #9 on: 27 January 2009, 18:51:50 »
vauxfan2k
  • Western Isles
Re: Rear demisters
« Reply #10 on: 27 January 2009, 18:53:58 »
Was it this http://www.omegaowners.com/forum/YaBB.pl?num=1232996661 ?
thats this thread dude ;D
vauxfan2k
  • Western Isles
Re: Rear demisters
« Reply #11 on: 27 January 2009, 18:55:37 »
just having my tea then ill go get them to take a pic.
 if I remember right, I may have 3 ducts, 2 of the same side
« Last Edit: 27 January 2009, 18:55:55 by Vauxfan2k »
vauxfan2k
  • Western Isles
Re: Rear demisters
« Reply #12 on: 27 January 2009, 19:14:24 »
Yep I do have 2 of the near side ones, as you can see, very awkward to replicate the ducts.
air is sucked into the opening seen in the middle motor, the hole in the door is there to allow air to get to this, and the gap in the door card is sufficient enough to not block it
« Last Edit: 27 January 2009, 19:15:58 by Vauxfan2k »
Bumbazor
  • Worksop
Re: Rear demisters
« Reply #13 on: 27 January 2009, 19:19:25 »
Cocks. So it is. I picked up the wrong link. Durrr.
Thanks for the pic. I can see the ducts are rather awkward.
Ive just found someone here who is hopefully sending me some, and hopefully will be fitting on Saturday.
vauxfan2k
  • Western Isles
Re: Rear demisters
« Reply #14 on: 27 January 2009, 19:23:18 »
did you change the rear door looms to elite looms? as the gls, cd, cdx dont have the connector for the motor. also pull the blank out of the dash where the switch goes to make sure the wiring is behind the switch  :y
