Pages: [1] 2 3  All   Go Down
Author Topic: Engine idles erratically, please help  (Read 7240 times)
dublin.jd
    • 01 Omega 2.6 MV6
« on: 21 November 2008, 17:55:11 »
My 98 R reg omega Idles very rough. (and stutters)
Once i reach 60-80 mph it also stars to judder but that seems to go if i put my foot down and drop a gear (kickdown)
I have replaced he coil pack, plugs, cleaned all breathers etc.
Nothing shows up on diagnostics.
Its a lovely car but I feel like driving it off the nearist bridge.
Please help.
Thanks
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
Re: Engine idles erratically, please help
« Reply #1 on: 21 November 2008, 17:57:13 »
the idling could be due to the icv (does it do it when warm or cold? )
also have the cleaner out the breather box thing at the rear of the drivers side cylinder bank?
V8!!!!
dublin.jd
    • 01 Omega 2.6 MV6
« Reply #2 on: 21 November 2008, 17:57:24 »
Sorry the car is An R reg (99) X25XEV Auto Elite
dublin.jd
    • 01 Omega 2.6 MV6
« Reply #3 on: 21 November 2008, 17:58:32 »
Always after about 1 min after cold start.
Thanks
ngrainqey
  • rotherham
« Reply #4 on: 21 November 2008, 17:59:31 »
does that mean its the newer plenium without icv and egr valve?
V8!!!!
dublin.jd
    • 01 Omega 2.6 MV6
« Reply #5 on: 21 November 2008, 18:00:36 »
Also cleaned breather box thing. The one with the naroow and fat hose
ngrainqey
  • rotherham
« Reply #6 on: 21 November 2008, 18:01:01 »
sory.. egnore that last post lol!
could be either an airleak or icv problems
my 2.0 used to cut out when it was warm and that was a problem with the ecv and the breather pipe
V8!!!!
dublin.jd
    • 01 Omega 2.6 MV6
« Reply #7 on: 21 November 2008, 18:01:45 »
No it has both egr and iacv
ngrainqey
  • rotherham
« Reply #8 on: 21 November 2008, 18:03:17 »
giving your icv a good cleaning out with carb cleaner could do alot also when were the breathers last cleaned?
V8!!!!
dublin.jd
    • 01 Omega 2.6 MV6
« Reply #9 on: 21 November 2008, 18:05:39 »
That worked on my 99 vectra 1600cc , i'll give it ago 2moro when its bright and you know. cheers mate
ngrainqey
  • rotherham
« Reply #10 on: 21 November 2008, 18:23:02 »
ok matey
on my 2.0 i poured surgical spirit down the breather pipe (going to the icv) and it came up top trumps ;)
V8!!!!
omegalad
« Reply #11 on: 22 November 2008, 01:17:18 »
i have the same problem with my omega 2001 2.2 auto it idles rough after a min when cold or so but judders on accleration at times no real power... whats an icv and ecr? where do i find these so i can clean them?
bear in mind i have had o2 sensor replaced, throttle body cleaned MAF replaced.plugs too. due to get exhaust replaced big hole in it.
what ye reckon?
« Reply #12 on: 22 November 2008, 10:22:18 »
Change the o-rings under the plenum , they are very cheap and helps the idle..
mike1
« Reply #13 on: 22 November 2008, 12:16:27 »
I have a 1997 2.5 v6 Auto which cuts out at junctions from time to time.Its just had a full service and no codes showed up on the coding m/c.could this be the same problam you are on about?
markey mark
  • SLady bitshorpe north lincs
« Reply #14 on: 22 November 2008, 12:53:19 »
what ye reckon?
coil pack on yours matey i would say ! :y
Pages: [1] 2 3  All   Go Up
