Author Topic: If its not one thing.........coolant problem  (Read 1231 times)
ScottieMV6
  • Swinton, Manchester
« on: 29 January 2009, 14:00:48 »
Just flushed heater matrix out - worked a treat, seem to have heat in car now. :y
However, I now have a new problem, coolant is now rising up the reservoir and overflowing out of the top (cap off).
Fix one problem and another appears!
I'd rather be scared to death than bored to death!!
Re: If its not one thing.........coolant problem
« Reply #1 on: 29 January 2009, 14:08:38 »
That's what's supposed to happen!  ;)  It should be a closed system ie witha pressure cap on. Put the cap on and run it.  :y
ScottieMV6
« Reply #2 on: 29 January 2009, 14:10:54 »
Ok :-[ Never seen that before but I will take your word for it and run it!
Cheers Andy. I will get your locking kit back to you now as well by the way! Anyday best for you? :y
« Reply #3 on: 29 January 2009, 14:14:07 »
 :y It's the same reason you don't take the cap off a hot/running engine. You end up scalded.  ;)
Any day is OK by me. SWMBO is off work next week & I'll be around over the weekend.  :y
