Author Topic: Random loose plugs? (pics)  (Read 1544 times)
GmasterT
  • Cambridge
  • does that drifting thing...
« on: 29 January 2009, 12:41:48 »
Right in my quest of curing miss-fire (plug wells still clean from the cleanup so could be the less than 2kmiles old plugs!) I discovered these two little randomers...
I assume one me be ex-plod spec, but any ideas?
from here
As always, many thanks!  :y
markey mark
  • SLady bitshorpe north lincs
Re: Random loose plugs? (pics)
« Reply #1 on: 29 January 2009, 12:48:20 »
the mutli pin one is for power sounder the other looks like coolant level  :-/
GmasterT
  • Cambridge
« Reply #2 on: 29 January 2009, 13:24:13 »
power sounder?!  :D
And I gather I have the wrong rad cap then?  :)
Bumbazor
  • Worksop
« Reply #3 on: 29 January 2009, 13:30:45 »
I think your coolant reservoir cap is correct. Mine's the same and if it gets low I get 'Coolant Level' warnings.
« Reply #4 on: 29 January 2009, 13:32:33 »
Coolant level sensor is UNDER the header tank ..  :)
GmasterT
  • Cambridge
« Reply #5 on: 29 January 2009, 14:39:40 »
ah! Will have a lookski, so the other one is an exlpod powr shower effort then...  :y
markey mark
« Reply #6 on: 29 January 2009, 14:49:48 »
just had a look at a facelift i have in garage and its for the bonnet switch matey so there both for the alarm system  :y :y
GmasterT
  • Cambridge
« Reply #7 on: 29 January 2009, 16:46:54 »
Ah, wondered why the car never complained about being locked with the bonnet open... switches muct have gone missing then... many thanks though  :y
