Author Topic: AR35 Gearbox  (Read 1317 times)
philhoward
  • Staffs
  • Love the engines, so put one in something else..
Re: AR35 Gearbox
« Reply #1 on: 29 January 2009, 20:53:48 »
I gather "yes", but need to reuse your TD bellhousing and torque converter.
Running an X30XE in a Reliant Scimitar GTE as I can't have an Omega as a company car...
unlucky alf
  • worksop, notts
Re: AR35 Gearbox
« Reply #2 on: 29 January 2009, 21:06:53 »
yup its just the job, but as phil says change the bellhousing & use your t/c, when changing bellhousing you might find it useful to have the g/box "nose up" so when you take it off the oil pump dont try & follow it, i propped mine up on an old tyre ;), i suppose itll be a chip next :y :y :y
philhoward
  • Staffs
Re: AR35 Gearbox
« Reply #3 on: 29 January 2009, 21:27:49 »
Ah yes - if anyone knows about TD gearboxes, it's Tim...you must have got the change down to an hour or so in the end?
unlucky alf
  • worksop, notts
Re: AR35 Gearbox
« Reply #4 on: 29 January 2009, 22:22:39 »
cheers phil ;D yes i can do it blindfolded now, & i trust you are basing that time including the 15 min teabreak ;D ;D, itll be coming out again once i find another bellhousing & t/c as the last time the bellhousing got a lump out of it & the t/c got a bit damaged on the g/box end, all due to the oilpump shattering :'( :'( ,its running o,k but im being fussy ;)
