Author Topic: Rear springs - best ones to get  (Read 1730 times)
    • 530D M Sport, 330i Coupe
« on: 30 January 2009, 17:45:15 »
Been to WIM today and now need to get some rear springs, car is a 3.2 Elite Saloon with air/self levelling shocks (I've got a new set of them to go on already).
Does anyone know a part number and price? They don't appear to be on the tradeclub site so if there is a better or more cost effective brand then any info would be appreciated.
Many thanks
Andy
« Last Edit: 30 January 2009, 17:49:33 by VXL_V6 »
Re: Rear springs - best ones to get
« Reply #1 on: 30 January 2009, 17:48:17 »
Watching this one as I need new springs too ::) ::) :y :y
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #2 on: 30 January 2009, 18:56:03 »
I've fitted BOGE coils and Monroe ride-leveller shock absorbers on several vehicles with no problems encountered.
Hope this helps fellas!
« Reply #3 on: 30 January 2009, 19:19:18 »
The only option for springs for self leveling suspensions are Gm at over 200 quid a pair
« Reply #4 on: 30 January 2009, 19:23:01 »
Arghhhhh!  :'(
Is it best to fit new springs or would a used pair off an elite be OK? Seems a shame to fit new shocks then skimp on the springs?  :-/
« Last Edit: 30 January 2009, 19:30:30 by VXL_V6 »
« Reply #5 on: 30 January 2009, 19:31:19 »
Sure I've seen pattern ones somewhere :-/ :-/ :-/
« Reply #6 on: 30 January 2009, 19:35:09 »
As Marks said. S/L suspension = OE springs :'( If suppliers say pattern will fit with S/L they`re talking sh*t :P
« Reply #7 on: 31 January 2009, 02:35:37 »
Right, with the knowledge that self levelling springs are dealer only... What's the difference between them and normal saloon ones?
stevief
  • Aberdeen
« Reply #8 on: 02 February 2009, 12:39:52 »
Been through this with the estate and when speaking to the manufacturers there comments were that they did not state that the aftermarket units were for use with S/L as they had not tried it themselves and therefore would not guarentee the outcome.
I've been running Eibachs for a year with no problems even when towing, the only difference being that the level does not have to drop as far before the levelling kicks in.
Steve
Seth
« Reply #9 on: 02 February 2009, 14:13:34 »
Yep, this sounds about right - we're into the actual technicalities of coil deflection here.
« Last Edit: 02 February 2009, 14:14:40 by Reliance505 »
« Reply #10 on: 02 February 2009, 21:47:33 »
So I could probably get away with standard springs then? Fitting's not an issue as I can always use my compressors :y :y
Page created in 0.008 seconds with 16 queries.
