Pages: [1] 2 3  All   Go Down
Author Topic: is this the HG gone  (Read 4907 times)
penny628
  • High Wycombe
is this the HG gone
« on: 01 February 2009, 23:59:25 »
can any one help me please im at a loss, I have a 2.5i v6 omega cd, it started with the heater blowing cold air, this was flushed by the garage but still does not work, then my car started to smell of like burning oil inside and out, I know have developed an overheating problem, there is mayo on the oil cap but the dipstick is clean i cant smell or see oil in the coolant tank, is this the HG or something else
Re: is this the HG gone
« Reply #1 on: 02 February 2009, 00:00:49 »
Unlikely HG
Where are you from...
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #2 on: 02 February 2009, 00:05:39 »
By what you have put above, burning oil could be your Cam Cover Gaskets, look to see if you have Oil in your spark plug wells...
Perhaps there is something wrong with your thermostat? the heat maybe something simple like the pipe come off the top of the HBV...
Are you losing coolant?
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
« Reply #3 on: 02 February 2009, 00:09:38 »
What is your location, as there might be a member near to you who can poss take a look for you?
Jaguar XJ6
penny628
  • High Wycombe
« Reply #4 on: 02 February 2009, 00:26:57 »
I am located in High Wycombe, yes I am losing coolant
« Reply #5 on: 02 February 2009, 07:01:53 »
Nope, if your dipstick is clean then no not hg, imho. Ignore the mayo in the filler neck, its caused by the neck sitting in colder air than the rest of the engine and condensation forming. Short journeys dont help, check it after a long run and it should have decreased if not burned off altogether.
The oil smell will be a leak of some sort most likely, probably cam cover seals, as said. Pull a few plug leads to check for oil in the plug wells.( Use genuine vx gaskits.)But most important make sure the breather system(blockage is usually the cause) is cleaned out at the same time or they will just blow again.
Coolent leaks are quite common on the omega and can be a pig to sort out, but the easiest fix and most common  cause is the heater bypass valve (hbv) at the back of the engine (35 from vx, again use genuine only) see if its wet or showing signs of residue of a similar colour to the coolent, if not your into the v of the engine for oil cooler cover plate, stat housing or coolent bridge.
The hbv is also involved in the heating system and "could"  be the cause, amongst other things, like the vacume pipe not connected to the top of it,as Entwood says, or vac pipes not connected to the bulk head, the vac system is relevent as it operates the vent motors and flaps in the cabin. But first thing to try is the auto reset on the climate controle(press and hold off and auto for 5 seconds or more, you should hear the motors chatter away for 30 seconds or so) if no luck check the 2 heater pipes through the bulk head are getting(very) hot when the engine is warned up. If not the heater wont work and would indicate a blocked matrix and may be a clue to over heating issue.
Over heating, check the fans are working (fuses?), and the rad has no cold spots. Hth.
Ps all the above are covered in the maintenance guides section, link at the bottom of my post.
Do you know of if the car has had oil cooler failure, or a stop leak addative in the coolent system at any point in the cars history?
penny628
  • High Wycombe
« Reply #6 on: 02 February 2009, 12:22:28 »
thankyou for your help all I can tell you is a stop leak was put into the system,I have checked the plugs now and there is oil in the wells, the car drives about 15 miles, then overheats this all started when the clutch went, the garage replaced the clutch blew my coil pack, sent the car back to me, had no revs on the counter struggled to drive it they drove it in 3rd gear said it was water in pertol tank, they decided to fix the heater they flushed the engine, replaced the coil pack new leads and plugs put on new cam sensor, car drove well power was all back except for burning oil smell in and out of the car then the car started to overheat thats when i checked the oil and saw the mayo on the cap dip stick was clear and no oil in the coolant.
« Reply #7 on: 02 February 2009, 12:27:49 »
Read this link. http://www.omegaowners.com/forum/YaBB.pl?num=1152564281 Should cure oil in the plugwells. How much coolant are you losing :question
penny628
  • High Wycombe
« Reply #8 on: 02 February 2009, 12:41:47 »
not losing a great deal of coolant, computer keeps saying no coolant even when its full though
« Reply #9 on: 02 February 2009, 12:56:34 »
That could be the sensor in the expansion tank knackered. When you say it overheats, what temp are you getting on the dash :question
penny628
  • High Wycombe
« Reply #10 on: 02 February 2009, 13:04:49 »
The temp guage is at the top and lights up red way past the 100 mark the fan kicks in and then stops i just stop and turn off the engine but i have had it tickng over for 40mins on drive no problem just when you drive it  thats when the smell of oil burning kicks in
MutantCav
  • Gainsborough
« Reply #11 on: 02 February 2009, 13:25:23 »
Coolant message when full will be the sensor on the header tank...get a decent second hand one and swap it over...5 minute job even for a novice...cam cover gaskets arent hard to change but sounds lke the garage you go to is incompetant, I would certainly consider going somewhere else!!
« Reply #12 on: 02 February 2009, 13:27:04 »
Oil burning smell is more than likely cam cover gaskets leaking oil. When it`s idling for as you say 40mins does the temp gauge redline :question
« Last Edit: 02 February 2009, 13:27:42 by RobG »
penny628
  • High Wycombe
« Reply #13 on: 02 February 2009, 13:40:11 »
Thanks so much will change the sensor and do the cam gaskets when ticking over for 40mins temp gauge did not redline only when driving it overheats should i check anything on the heater as it blows cold air only sorry to be a pain
« Reply #14 on: 02 February 2009, 13:41:07 »
Check the fuses in the engine bay ECU box.
Where are you?
« Last Edit: 02 February 2009, 13:41:26 by Mark »
Pages: [1] 2 3  All   Go Up
Page created in 0.021 seconds with 16 queries.
