Author Topic: What bulbs go behind the dashboard?  (Read 1241 times)
jamescropley
  • Grantham, Lincs
« on: 04 February 2009, 01:20:03 »
Ok, my dashboard lights arnt working, nor are the central control lights eg: rear heated window heated seats etc. I've checked the fuses and they are all ok. Before i pull out the dash, does anyone know the specific bulb/s i would need to replace the blown one/s with? Makes it easier if i know beforehand :o)
Many thanks.
Pete Elite
  • Uxbridge, Middlesex
Re: What bulbs go behind the dashboard?
« Reply #1 on: 04 February 2009, 01:28:34 »
  I know the ones behind the dials are three capless 501s but not sure about the others :).
jamescropley
  • Grantham, Lincs
« Reply #2 on: 04 February 2009, 01:45:53 »
Thanks Pete, someone told me that the bulbs all run off each other so if one goes out, the rest fail to work. Im not sure about that but i couldnt see all bulbs blowing. I'll have to have a look. If only it were summer and not bloody freezing!
jamescropley
  • Grantham, Lincs
« Reply #3 on: 04 February 2009, 01:53:21 »
Does anyone have a vid/step by step instruction for replacing bulbs, just incase i go wrong (which will probably be the case)
thanks
Pete Elite
« Reply #4 on: 04 February 2009, 01:54:36 »
No they only go out one at a time. I'm not sure if the bulbs in the switches are changeable or are like the Senator/Carlton ones which if blown require a new switch :-/. I'm sure someone on here will put you right :).
Pete Elite
« Reply #5 on: 04 February 2009, 01:58:31 »
thanks
     Try this James :).
         http://www.omegaowners.com/forum/YaBB.pl?num=1192573381
jamescropley
  • Grantham, Lincs
« Reply #6 on: 04 February 2009, 02:05:15 »
Thanks Pete, I guess the dash just pulls out? I'll have a go in the morning.
Cheers
Pete Elite
« Reply #7 on: 04 February 2009, 02:14:42 »
  Yep James, really is a piece of cake an idiot could do, well must be i did it ;D.
