Author Topic: Does the Eilte,s have .....  (Read 3178 times)
SP_3.2
  • Leicester
    • drives A6 allroad 3.0tdi
« on: 01 February 2009, 20:33:55 »
Just thinking after my drive that i remember hear somewhere that the Elite have heated jet washer for the screen and lights is that right :question.
And if so are they on heat all the time or do you have to have the rear screen heater on.
Thanks
Steve
Re: Does the Eilte,s have .....
« Reply #1 on: 01 February 2009, 20:41:40 »
You'll have heated screen washers, look in the scuttle where the washer jets are & on the nearside bonnet hinge there's a 2 pin plg for them. Not sure when they're live though. :-/
« Reply #2 on: 01 February 2009, 20:44:09 »
they are attached to the washer nozzle in the bonnet,and come on with the heated screen afaik.dont know about headlight washers. :y
« Last Edit: 01 February 2009, 20:44:30 by albitz »
    • 530D M Sport, 330i Coupe
« Reply #3 on: 01 February 2009, 20:45:30 »
Manual doesn't seem to say, I would reckon they either come on with the heated rear window or automatically by the outside temp sensor.
« Reply #4 on: 01 February 2009, 20:53:30 »
Face lifts are in the scuttle!  ;) ;) :y
vauxfan2k
  • Western Isles
« Reply #5 on: 01 February 2009, 20:54:46 »
heated washer jets come on with the rear window. altho due to them getting soaked in water everytime you use them the wiring corrodes and breaks off, so they may or may not work. best bet is to pop them out and have a look. if the wires are broken, you can clean up the contacts and resolder them. done a few now.
SP_3.2
  • Leicester
« Reply #6 on: 01 February 2009, 21:01:25 »
Thanks everyone will have a check . When i gave them a try i did not have the rear heater for the window on. Will try with it on....sure that i wll get a chance on Monday the way that things are looking like outside -3. :o :o
« Reply #7 on: 01 February 2009, 21:23:24 »
IIRC, my heated washers are live all the time. They come on with position II of the ignition switch.
« Reply #8 on: 01 February 2009, 21:45:23 »
Must confess I thought they came live with the ignition :-/ :-/ :-/
vauxfan2k
  • Western Isles
« Reply #9 on: 01 February 2009, 21:47:21 »
Must confess I thought they came live with the ignition Undecided Undecided Undecided
that would be a silly idea as it could be a cracking day outside 20 degrees and sunshine and your washers would be cooking away for no reason.. surely vaux werent that daft.  :D
philhoward
  • Staffs
  • Love the engines, so put one in something else..
« Reply #10 on: 01 February 2009, 21:50:02 »
According to the BOL wiring diagram they do...
Running an X30XE in a Reliant Scimitar GTE as I can't have an Omega as a company car...
« Reply #11 on: 01 February 2009, 21:51:32 »
What a ridiculous comment ::) ::) ::)
They stopped making the Omega didn't they ;) ;) ;)
« Reply #12 on: 01 February 2009, 21:53:01 »
Even worse ... they supposedly replaced the Senator with an Omega!  :-?  :-?  :y
vauxfan2k
  • Western Isles
« Reply #13 on: 01 February 2009, 21:56:11 »
they replaced the carlton and senator with the omega  ;)
« Reply #14 on: 01 February 2009, 22:13:04 »
allegedly! ........
