Author Topic: MV6 3ltr Help  (Read 2766 times)
sophos9
  • Norfolk
MV6 3ltr Help
« on: 04 February 2009, 09:57:00 »
Hi,
I'm on the verge of buying a facelift MV6 barge - the particular one is advertised with one tappet is noticeable from cold start but soon becomes quiet - comes with full service history though...
Last cambelt change was at 61, car is now on 103k so needs to be done regardless (got the kit and have done it before)
How much of a problem is one tappet from cold (presuming its the tappet and not the tensioner) - apparently its done it for about the last year?
Thanks in advance
« Last Edit: 04 February 2009, 10:13:16 by sophos9 »
Re: MV6 3ltr Help
« Reply #1 on: 04 February 2009, 10:02:36 »
It could be an exhaust manifold gasket blowing which is quite common. If it is the follower tapping a few short oil changes could do the trick, if its the exhaust manifold gasket, I hope its the driverside ;)
sophos9
  • Norfolk
Re: MV6 3ltr Help
« Reply #2 on: 04 February 2009, 10:08:17 »
Yea, passenger side is an engine out(ish) job right?
How would I diagnose this and what are the implications of a blowing exhaust gasket?
Thanks mate
sophos9
  • Norfolk
Re: MV6 3ltr Help
« Reply #3 on: 04 February 2009, 10:30:05 »
Another things - are MV6's manual transmission not auto (or was it an option?)
« Last Edit: 04 February 2009, 10:32:12 by sophos9 »
Re: MV6 3ltr Help
« Reply #4 on: 04 February 2009, 10:32:07 »
Thanks mate
The passenger side gasket requires the engine lifting off its mountings and moving over slightly. I would get the bonnet up and have a good listen down the side and ontop of the engine to pinpoint where the noise is coming from.
sophos9
  • Norfolk
Re: MV6 3ltr Help
« Reply #5 on: 04 February 2009, 10:34:06 »
Bugger - the car is about 150miles away so travelling to do a diagnoses is an arse...
Will contact the seller initially and ask them what side of the engine bay its coming from, if its passenger then I dont think I'll bother with it
Re: MV6 3ltr Help
« Reply #6 on: 04 February 2009, 10:37:00 »
If the car is cheap enough then its worth doing, its not that bad a job ;)
Re: MV6 3ltr Help
« Reply #7 on: 04 February 2009, 10:37:41 »
Where is the car, it might be possible for someone off here to go and have a look ;)
MutantCav
  • Gainsborough
Re: MV6 3ltr Help
« Reply #8 on: 04 February 2009, 10:38:12 »
What kind of price is it...if its reasonable enough then may as well get it anyway  :y
sophos9
  • Norfolk
Re: MV6 3ltr Help
« Reply #9 on: 04 February 2009, 10:45:03 »
Hi,
Its £1400 for a 3ltr MV6, FSH with 103k on the clock - all round good condition
Only other thing wrong is drivers heated seat does not work (they all fail dont they  :) )
Thinking of offering £1200 in light of the cambelt change
What you think?
Re: MV6 3ltr Help
« Reply #10 on: 04 February 2009, 10:47:27 »
If its a 3.0 I presume its a 99 to 2001 in which case I would say its a bit expensive, has it got leather?
sophos9
  • Norfolk
Re: MV6 3ltr Help
« Reply #11 on: 04 February 2009, 10:52:48 »
DOH! Year might help - its a Y - 2000...
Yep, leather and all the normal stuff - no sat nav though :(
Re: MV6 3ltr Help
« Reply #12 on: 04 February 2009, 10:55:38 »
could the tappet noise from cold be a lazy lifter, as is common on the 3.2? Usually cured by an immediate and further oil changes at 3-5k intervals.
Or is this less common on short plenum engines?
MutantCav
  • Gainsborough
Re: MV6 3ltr Help
« Reply #13 on: 04 February 2009, 10:58:23 »
Pretty common...will have a long plenum anyway lol
sophos9
  • Norfolk
Re: MV6 3ltr Help
« Reply #14 on: 04 February 2009, 11:02:48 »
Yep is a long plenum...
So - is an offer of £1200 too much still, please post what you would give for it ;)
